Old 08-19-2019, 03:50 PM #1
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Parking brake issue after axle swap
Need some help, I’m about 90% thru a rear axle swap and can’t my parking brake cable set. I can pry the bell crank out to make the cable clevis reach, but obviously that sets the parking brake, even with the handle down.
I swapped the axle shaft/brake assy from my current axle into the new housing, same brake cable. I didn’t even pull the drums off of the axles so I’m not sure why I can’t make it reach.
Drums won’t come off, even trying to press them off with an M10 screw thru the threaded holes
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 03:56 PM #2
RS Dude's Avatar
RS Dude RS Dude is offline
RS Dude is on a distinguished road
RS Dude's Avatar
You can loosen the tension of the parking brake cable at the brake handle.
'96 T4R SR5 V6 Auto 2WD 329,000 miles
RS Dude is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 04:02 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Try loosening the parking brake cable at the lever. For the drums you'll probably need to loosen the brake adjuster before the drum will slide off.
Old 08-19-2019, 05:37 PM #4
thezentree's Avatar
thezentree's Avatar
Thanks, I'll give that a shot. Not sure what's changed, but maybe the bracket locations are slightly different?
Yeah I finally got the adjuster to move, so I was able to get the drum off.
Old 08-19-2019, 08:58 PM #5
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
Yep. Loosen as a much as possible at the handle.
BrianK14 is offline   Reply With QuoteReply With Quote
axle , brake , cable , make , parking
Parking brake noise issue autoxr37 4th Gen T4Rs 14 10-12-2020 07:00 PM
DIY Rear Axle Seal and Parking Brake 46runner Maintenance/Detailing 5 04-24-2020 01:02 PM
Parking E brake Issue DannyLlama 5th gen T4Rs 4 08-05-2014 10:54 AM
1988 4runner Swap Parking Brake Zorlac Classic T4Rs 8 02-11-2013 02:47 PM
Parking Brake Issue JP4RNR 4th Gen T4Rs 12 10-17-2006 04:34 PM
