Old 08-20-2019, 07:43 PM #1
anniesball72's Avatar
anniesball72 anniesball72 is offline
anniesball72 is on a distinguished road
SR5 climate control manual temperature control dial
In my truck 2002 SR5, it has started blowing hot air regardless of what position the temperature mix dial is set at. But...
If it's sat overnight and the AC was on cold and the dial is set to cold it will start up and eventually start blowing hot air (when the engines warm). When I notice it's hot not cold, I can simply turn the dial from cold to hot to cold again and it will blow cold.
Lately I have to do that more frequently when driving to get it to blow cold.
What I don't understand is if there is a servo or other controlling the hot water valve or the air mix? If it's simply the cable I'm cornfused as it would be purely manual and would work fine.
I have searched our forums and others for a solution and was unable to find something similar to my situation.
02 SR5, manual hubs, 3” lift, airbags, 5-speed swap with locking center diff, 1st gen supercharger, URD 7th, BAMF sliders.
anniesball72 is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 07:52 PM #2
The 01/02 SR5 AC system is at least partially electronic (not fully auto), unlike the earlier base/SR5 AC controls. That would explain the wonkiness.
Hopefully somebody has a good idea for a fix. It might be simple, like re-soldering a few components.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-20-2019, 11:21 PM #3
Thanks, I can't find much info on it readily available. May have to crack the FSM.
air , cold , dial , hot , start
FS: [NJ] 01-02 Manual Climate Control - $27 + shipping spazzyone For Sale: T4R Items 2 02-14-2017 06:46 PM
Climate control temperature desch 5th gen T4Rs 6 09-06-2013 12:30 PM
Auto Climate Control vs. Manual Climate Control JME476 3rd gen T4Rs 2 04-07-2008 01:04 AM
'02 Upgrade standard climate control to auto climate control unit? bradym239 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 06-10-2004 01:37 PM
Manual to automatic climate control TimT 4th Gen T4Rs 9 03-23-2004 02:30 PM
