06-26-2011, 01:02 AM
FJ80 Wheels and lugnuts
I just got my FJ80 wheels finally put on my 4Runner. The tech at the tire ace said I may want to make sure I have the correct lugnuts for the wheel. Do I have to swap out lugnuts from a 4Runner to a Land Cruiser type? The washer around the lugnuts now is loose. I kinda want to switch over to black lugnuts anyway.
Thanks
Bob
1997 Toyota 4Runner Limited 3.4L
Mods: Deckplate, ISR, Various LEDS
Exhaust: Magnaflow Cat and Muffler
Susp: 3" Toytech w/LC Coils, 285 AT2s
06-26-2011, 01:49 AM
When I switched from the split spoke wheels to the LC wheels I had to get new lug nuts. It seems odd that the tech wouldn't know the correct lugs for the style wheel. I have also heard that only some LC wheels have different lug nuts than the 4Runner but haven't seem it first hand.
1997 5spd 4x4 lifted, armor, etc. - sold
2006 4Runner Sr5 V6 2wd - Wife's daily driver
06-26-2011, 02:36 AM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
This has been covered quite a few times. '93 & '94 LC80 wheels use tapered seat lugs. '95+ LC80 wheels use the mag seat lugs, which are the same lugs all 3rd gens come with.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
06-26-2011, 03:32 AM
You can easily tell because the 93-94 wheels had a black steel insert in the wheel that the lug nut would go on top of. The 95-97 were all aluminum. I have the 94 wheels and ordered a set of lug and locks from wheelers off road for fairly cheap.
1997 4runner Limited 4wd- Purchased new by family 12/96
Factory 4.30 e-locker conversion, 265/75 BFG AT, FX-R Hid Retrofit, Kenwood Nav, 231mm Tundra brakes, Grey FJZ80 Wheels, Deckplate mod, ARB Bumper, Hella 4000 compacts, Sonoran Steel 7.2a, Scangauge 2, Extended Diff Breather, Custom Sway Bar Endlinks, Black No Rust Rear Bumper
06-26-2011, 11:21 AM
That is all...
'99 SR5 Silver 2WD.
Full LED Conversion. 6000k V-HIDs.
Hella Micro Des.
D-Shackles. LC80 rims.
20% tint front windows. Memphis 15"
06-26-2011, 11:34 AM
I would question the tech if he said that. cause I would think any style would work in an emergency to get home, but its pretty obvious that a lug nut is the right one or not.
I just put my LC wheels on and am very happy with them. but I got lucky on when I bought the wheels that I didn't have to change out the lug nuts.
what color did you go with?
pics are always good when you do something to your runner, cuase we like to share the excitement with you. here is a pic of mine minus the caps
SOLD- 00 5spd, rear locker, OME 882/890, CBI front bumper, rear swing away, sliders by CBI too, warn M8000, Lightning force 170's, 265/75/16, (on the list, roof rack) LC wheels (graphite), diff drop, http://www.toyota-4runner.org/3rd-ge...ld-thread.html
06-26-2011, 02:39 PM
Pics will be posted tonight to tomorrow...I promise. I've done alot since the lift.
So I need to order 12 x 1.5 lug nuts in acorn or ball/round shape? Also am I safe to drive on the lug nuts I have now?
Thanks
Bob
06-26-2011, 02:41 PM
MTDEWX8, I stayed with the stock color for right now, but I'm painting the caps black and looking for black lug nuts
06-26-2011, 03:26 PM
Thanks
Bob
You are safe to drive on the lug nuts you have for now.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
07-07-2011, 11:10 AM
Sorry for the late pic and broke promise, hahah. Here is a pic of what she looks like now...
07-07-2011, 01:26 PM
Real Name: Sam
Real Name: Sam
Looks Sweet
84 Crawler Rockdawg84s Pic build thread but mostly pics
94 Fzj80 family hauler - sold
98 SR5 supercharged 5speed on 35's, dual locked, dual cased Smokey build Thread
03 SR5 V8, 4x4, 2.5" Icon's with 35's -Sold The Wife's 03 Build Sold
07-07-2011, 03:04 PM
LOVE those wheels on 3rd gens!
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
08-13-2015, 10:04 AM
Looking at a set of these Fj80 16x8 on craigslist. Will bolt right on with the correct lugs?
I read they do not clear the tundra brakes, I had not done this upgrade yet but was thinking about it.
08-13-2015, 10:42 AM
Real Name: Throws like a girl
Can confirm this style does not clear the tundra brakes. I use a 1" wheel adapter to solve that.
EDIT:
This is the Land Cruiser wheel I am referring to, with the acorn lug nuts.... (should have posted this earlier, sorry!)
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
08-13-2015, 02:05 PM
Originally Posted by habanero
Can confirm they do not clear the tundra brakes. I use a 1" wheel adapter to solve that.
Thanks, rotors are def warped so I will be doing my first brake job...more likely Ill get scared and have my mechanic down the street do it. May just replace with 4Runner standard.
LC wheels are $180 which I think is a good deal for a set of 4.
