Old 08-29-2019, 08:31 PM #16
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Originally Posted by Arv View Post
I actually got my 99 talls last night from Camelback Toy and they were pretty beat up, lots of scuffs and some minor chips. Quite disappointed really but its back ordered and won't get replacements tilnext week so I'll stick with what I have because i wnt to do it this weekend.
Maybe they have been sitting around a warehouse for a LONG time. Give them a quick spray of good rust paint. It'll help protect them a bit in the long run.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 09:40 PM #17
Arv Arv is offline
Arv is on a distinguished road
Arv Arv is offline
Yeah I think I'm just going to touch up the really bad areas, don't want to risk the paint peeling or cracking from flexing. I just can't believe I have to do this after spending so much on springs, I really thought about going the after market route really hard.
Arv is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 11:15 AM #18
Kanoe's Avatar
Kanoe's Avatar
The aftermarket springs I have touched (moog and OME) don't have anything special paint wise either. Moogs being worse than OME of course. I have sprayed all of mine with some rust paint, both used springs and new ones. The paint has not cracked or flaked a bit on any. You can't go wrong. I just put a little painters tape over the color code so they still look like OEM when I am done.
-2001 Echo D.D.
Old 08-30-2019, 01:47 PM #19
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
I've had energy suspension bushings before on my Honda and they squeak, would that be the same case for these isolators? If so what do you recommend.
Hey Arv,
James here from Energy Suspension. You'll only be able to experience squeaking from an improperly lubricated pivoting part, such as a control arm bushing, leaf spring bushing, or potentially a sway bar bushing where the bar pivots within the stationary bushing. The trick is to liberally grease these types of parts and wipe up the excess when it's all installed. 99% of the time, when I get a call about squeaks, the folks on the other side of the phone have not used all of the included grease that came with their kits.
On a coil spring isolator, there's no chance for any squeaking as the isolators and coil springs do not rotate within their assemblies. You'd be all set without having to do any lubricating.
Take care.
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 03:26 PM #20
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
Originally Posted by pentagrammaton View Post
when y'all talk about the moog 99 talls, are they these ones? --> 81043
No, the 99 talls are #81041
I just checked Amazon, and they are $50 now
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 04:33 PM #21
pentagrammaton pentagrammaton is offline
pentagrammaton is on a distinguished road
Not sure, I did encounter that part number a few times when I was doing my research but I was set on OEM.
Gotcha, I probably won't go OEM, too pricey.
1997 4Runner SR5
pentagrammaton is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 04:42 PM #22
Got it, thanks!
(81043) 15.1 x 11.1 x 5.1 inches
(81041) 20 x 11.1 x 5.1 inches
I can't seem to find the specs for the OEM toyota spring (4823135200)
1997 4Runner SR5
coil , isolators , recommend , springs , tall
Anyone running the new Bilstein 24-248730 / 24-249966 shocks? Opinions? thor999 3rd gen T4Rs 54 07-10-2018 12:32 AM
Front rubber coil spring isolator having fun 4th Gen T4Rs 5 01-08-2013 08:19 PM
Coil Spring Isolator NickS040 4th Gen T4Rs 4 09-29-2012 03:02 PM
WTB Stock Coil Spring Isolator NickS040 Want to Buy/Trade 0 09-15-2012 05:29 PM
WTB: Rear Coil Spring Isolator ARK_SWAMP_RIDER Want to Buy/Trade 5 09-10-2011 09:06 AM
