Old 08-21-2019, 06:07 PM #1
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
Rag Joint Bolt Size
What are the OEM bolt specs that are pulled out and replaced with longer ones whenever you are doing a body lift?
These are the final two bolts i need to get to be able to successfully remove the body lift this weekend.
I tried contacting Toytec and inquired about what length bolt they supply for the 2inch but I got no response.
Tried searching the web for the stock size but no luck. i swore i have found some good threads with bolt sizes around here somewhere but I can not pull it up.
Time is ticking till i start busting butt on it! I live out in the middle of no where so whatever i can grab while I got nothing can do saves me half a day!
Someone help please!
STI_MECE is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 06:49 AM #2
STI_MECE's Avatar
STI_MECE's Avatar
Well I think I found it.....but not 100% sure if that's the OEM length.
Bolt size is 8x25 (diameter x length).TPI is 1.25 if I recall correctly. You will need flanged nut
OEM is grade 5, don't think you can go wrong with grade 8. Torque spec is 15-20 ft lbs.
If anyone believes this is wrong please chime in. I'm going to hardware store tonight before I start my drive back home.
For reference, I live where you guys like to drive the 4runners on trails. IE. In the middle of the no where lol 1 screw up and it costs me half a day minimum to get a bolt.
Found it here: Body Lift Installation Instructions
Old 08-28-2019, 05:32 PM #3
STI_MECE's Avatar
STI_MECE's Avatar
Just for anyone who needs to know the bolt size, its a M8x25mm.
body , bolt , lift , size , ticking
Bolt size Daddycreswell General Discussions 4 07-03-2019 12:25 AM
Missing a bolt on lower ball joint! david.b 3rd gen T4Rs 12 06-29-2017 10:12 PM
Looking for a lower ball joint bolt (westminster, co) blonde1boarder 3rd gen T4Rs 14 11-13-2014 07:22 PM
Help with bolt size... mikey's2010SR5 5th gen T4Rs 10 01-21-2014 08:09 PM
uball joint bolt fell out after cornfed install irwinSR5 4th Gen T4Rs 6 07-22-2007 01:22 PM
