Originally Posted by Brian.
Regular. At least based on the Rear's I've installed (906, saw a 1.5" change from 200k mile old originals). Expect a 1" change when installed on a '99. That's 23inch from hub center to the bottom of the Limited flare.
Thanks. I got the same result with rear springs. I needed something to handle multiple trips with half a ton of wood pellets and the coils are doing great at that. Issue I have is that the front leans a bit on turns while the back tries to stay balanced. My front coils are old with 184k so its time.
I think they will do well with the 4600's so I will leave those be. I rather have the full package knowing they are designed to work together (had multiple OME systems on my jeeps) but these shocks arent even two yrs old so I can't justify replacing them.
