Old 08-25-2019, 02:12 AM #1
Mudeprived Mudeprived is offline
Mudeprived is on a distinguished road
Quick OME coil question.
Is their advertised (approx) lift height going by the regular oem coils or 99 talls?
I need new coils for the front of the 99 Limited and want to match the rear OME coils but no more than inch of lift.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Mudeprived is offline   Reply With QuoteReply With Quote
Old 08-25-2019, 08:21 AM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Regular. At least based on the Rear's I've installed (906, saw a 1.5" change from 200k mile old originals). Expect a 1" change when installed on a '99. That's 23inch from hub center to the bottom of the Limited flare.
Brian. is offline   Reply With QuoteReply With Quote
Old 08-25-2019, 11:04 AM #3
Thanks. I got the same result with rear springs. I needed something to handle multiple trips with half a ton of wood pellets and the coils are doing great at that. Issue I have is that the front leans a bit on turns while the back tries to stay balanced. My front coils are old with 184k so its time.
I think they will do well with the 4600's so I will leave those be. I rather have the full package knowing they are designed to work together (had multiple OME systems on my jeeps) but these shocks arent even two yrs old so I can't justify replacing them.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Old 08-25-2019, 12:18 PM #4
Cade7H Cade7H is offline
Cade7H is on a distinguished road
Spring Question
Im wanting to get a OME 880/906 set up. What shocks should i be looking for?
Cade7H is offline   Reply With QuoteReply With Quote
Old 08-25-2019, 05:51 PM #5
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
You can get away with stock replacement shocks, or T4R specific 5100s for those springs. The lift isn't dramatic.
Check this thread: Absalom's Cookie Cutter 4runner Builds - New and Updated!
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 08-25-2019, 06:06 PM #6
Jeckolame Jeckolame is offline
Jeckolame is on a distinguished road
+1
Jeckolame is offline   Reply With QuoteReply With Quote
Old 08-25-2019, 06:11 PM #7
Thats really good information, but im still unsure about the shocks. Would stock shocks limit my travel? Ive read this but maybe doesnt matter ith such a mild lift: 1" in front and 2" in back.
coils , front , lift , ome , quick
Quick Mud flap rub question and rear coil break in? fastdiablo 5th gen T4Rs 1 06-15-2018 01:29 PM
ARB fridge:quick question hoping for a quick answer familymopar 5th gen T4Rs 5 09-04-2016 01:33 PM
Quick fj coil question Whodat504 4th Gen T4Rs 11 08-19-2013 09:35 AM
Very Quick Rear LC coil question ryankmasuda 3rd gen T4Rs 3 05-23-2011 01:10 PM
sorru quick question trucks at the shop, coil replacement? theizzardking 3rd gen T4Rs 16 12-06-2010 10:39 PM
