Originally Posted by Sarki
Snap a picture and post if possible.
Cracked valve cover at mounting area near bolt from an over zealous prior owner cranking down on the bolts holding down the cover?
The valve cover gasket design on the 3.4L leaves something to be desired and is prone to leaking over time/miles.
Even after installing a fresh one, you need to tighten the valve cover bolts every few oil changes as the rubber on both the VCG and the bolt-washers harden and compress. If left untouched, the lower rim of the valve covers will leak eventually.
The location of the leak you are mentioning, however, is right near the power steering pump. Are you sure it's engine oil you are leaking?
1999 Toyota 4Runner SR5 Sport 4WD, V6 5-Speed e-Locker->
4WD 4runner Journal Thread
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->
2WD 4runner Journal Thread
