Old 08-25-2019, 12:44 PM #1
vesteroid vesteroid is offline
vesteroid is on a distinguished road
Oil leak on upper passenger side
I went to change my oil yesterday and the skid plate was covered. All the diff was covered, and steering rack.
I degreased the engine, power washed it and wiped it down clean with towels.
I took it for a drive for about 45 minutes and there is oil collecting on the ac compressor and it had just run down enough to start around the oil pan.
I can’t see any oil from the side of the valve cover so I am guessing it’s up front under the timing cover.
Going to try and pull the timing cover now that it’s all cooled off.
Any thoughts on how to pin this down?
vesteroid is offline   Reply With QuoteReply With Quote
Old 08-25-2019, 12:53 PM #2
nissanh nissanh is offline
Have you checked the PCV valve area?
Old 08-25-2019, 01:02 PM #3
It’s clean
Old 08-25-2019, 01:54 PM #4
I pulled the cover and still can’t really see anything. There is a metal shield behind,the pulley that blocks my view.
I am guessing it al,ost has to be the valve cover gasket as I can see it’s right on top of,the ac compressor
Old 08-25-2019, 01:58 PM #5
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Sounds like the semi circular (half moon) plug in the front is leaking.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 08-25-2019, 02:17 PM #6
So far I can’t get the lower left bolt out of timing cover #2. But I can get a tiny view of the half moon. Seems the rtv is kind of pushed out st the bottom into almost a tail or spout type shape...really hard to see.
If I didn’t have the top radiator hose off I would love to start it and see if I can see any oil.
Old 08-25-2019, 02:24 PM #7
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Sounds like most likely valve cover gasket replacement is in your future.
Got the same project ahead of me and not looking forward to it.
Seems like it’s a “right of passage” to all 3rd gen 3.4 liter owners once the miles start adding up.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 08-25-2019, 02:47 PM #8
I put it all back together and took it back out into the sun. It’s not coming from where I saw the rtv. I can see it right on the volt closest to the block that appears to be holding the ac compressor on. It pooling right there. I can’t see any evidence it’s coming from,the valve cover. No oil on the intake side.
That compressor appears to be below the head....what else could it be on the front on that side. It’s running fine. No water in the oil.
Old 08-25-2019, 03:24 PM #9
Snap a picture and post if possible.
Cracked valve cover at mounting area near bolt from an over zealous prior owner cranking down on the bolts holding down the cover?
2002 SR5 Sport 4WD
Old 08-25-2019, 05:48 PM #10
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
The valve cover gasket design on the 3.4L leaves something to be desired and is prone to leaking over time/miles.
Even after installing a fresh one, you need to tighten the valve cover bolts every few oil changes as the rubber on both the VCG and the bolt-washers harden and compress. If left untouched, the lower rim of the valve covers will leak eventually.
The location of the leak you are mentioning, however, is right near the power steering pump. Are you sure it's engine oil you are leaking?
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 08:34 AM #11
I thought it was power steering at first and replaced,the pump and changed the fluid. I am pretty convinced now it’s motor oil because I wiped up some after the clean up and it was not pink
Old 03-22-2022, 03:54 PM #12
psea17 psea17 is offline
psea17 will become famous soon enough
wondering if you ever found the oil leak? thx
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 03-23-2022, 09:29 PM #13
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
i now have an oil leak same place. leaks down on cross over pipe...its my vc gasket
Old 03-23-2022, 11:58 PM #14
fatherohenry's Avatar
fatherohenry fatherohenry is offline
Real Name: Mark KN6TZI
fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough
This has been on my mind since I recently did the VCGs. There's only one way to get to the inner VC bolts on the left side, correct? Guess I should have bought extra intake manifold gaskets.
'96 T4R SR5 | 4WD | Auto | 199 TBU | 268k+
fatherohenry is offline   Reply With QuoteReply With Quote
Old 03-24-2022, 10:31 AM #15
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
You will be fine reusing the metal intake manifold gaskets a couple times
Bad Luck is online now   Reply With QuoteReply With Quote
cover , covered , it’s , oil , timing
3.0 oil leak on passenger side kc15842 Classic T4Rs 12 07-18-2017 07:38 PM
WTB: 4th gen Rear Bumper Upper Retainer (Passenger side) tranmd Want to Buy/Trade 8 03-16-2013 01:50 AM
Passenger Side CV Boot Leak Noloc Problems & Warranty Issues 5 11-30-2009 11:07 AM
leak under passenger side maximilian 3rd gen T4Rs 9 08-16-2007 10:45 AM
