Old 08-09-2021, 06:12 PM #16
Toystory2's Avatar
Toystory2 Toystory2 is offline
Toystory2 will become famous soon enough
Toystory2's Avatar
Originally Posted by octanejunkie View Post
Not sure if this has been documented but here is my version. Pics to follow.
The AC drain fitting is a small aluminum pipe with a right angle bend towards the bottom of the firewall right above the steering rack on the passenger side. When the AC drains it leaks all over the rack, boot, tie rod ends, etc. It's annoying.
The aluminum drain fitting is secured to the AC evaporator housing via a rubber grommet on the firewall, and if you are careful you can wiggle the fitting out. Which I did. I installed about 18" of 3/8" ID vinyl hose from Home Depot that i had lying around onto the aluminum drain fitting on the outboard side.
I then snaked the drain hose assembly I made back up to the firewall starting outside the frame rail, under the rubber splash guard and up to the grommet. I lightly lubed the aluminum drain fitting and pushed it back into the grommet. Now you can trim the 3/8" hose to length and call it good.
Now, when my AC drains, it drains directly onto the ground and not on my steering and suspension components. This is roughly a $1 mod that takes about 10-15 minutes to perform and is worth about twenty bucks in piece of mind, to me at least.
Any pictures of this by chance?
Toystory2 is offline   Reply With QuoteReply With Quote
Old 08-09-2021, 06:26 PM #17
HiLife HiLife is offline
You need to scroll up...
Old 10-12-2021, 03:35 PM #18
sugjavier sugjavier is offline
sugjavier will become famous soon enough
Originally Posted by Brian. View Post
I did this the other day while torquing the cam adjuster bolts following an alignment. Just used some clear polyvinyl hose that was laying around and zip-tied it to the bracket for the body bushing just at the hinge side of the front door.
And this is the "stock" end of it, for those who need better visual reference (or you could just drive it with the AC on and follow the leak):
Hey guys, I want to do this mod but when I checked, I don't even have the L shaped metal LOL
Imgur: The magic of the Internet
Is this the part I'm missing???
Drain hose Connector - Toyota (88894-35080)
1999-2002 Toyota 4Runner Connector 88894-35080 | Toyota Parts
2001 Toyota 4Runner Limited. 231k miles.
sugjavier is offline   Reply With QuoteReply With Quote
Old 10-12-2021, 04:52 PM #19
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
I didn’t have that connector either! Yes that’s the right part.
JZiggy is offline   Reply With QuoteReply With Quote
Old 10-13-2021, 03:39 PM #20
https://www.homedepot.com/p/UDP-3-8-...304185141-_-N&
Is this the correct size 3/8" Inner Diameter x 1/2" Outer Diameter?
Old 01-26-2022, 02:22 PM #21
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
3/8" ID yes
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 02-08-2024, 10:35 AM #22
MY_FRAME_IS_RUSTY's Avatar
MY_FRAME_IS_RUSTY MY_FRAME_IS_RUSTY is offline
Real Name: Jakob
MY_FRAME_IS_RUSTY is on a distinguished road
Real Name: Jakob
Originally Posted by rdruss View Post
I did similar on my 4th gen as it drains right on top of PS frame rail and mine has a large rotted hole on bottom of frame where the drips would collect and drip on ground, about 13 years of that did some damage. See my garage.
Looked for OP’s post for exactly this reason. I thought it wouldn’t be that big of a deal as long as I treated my frame once a year so I went without doing this mod as soon as I bought the car 2 years ago. Found a nice big crevasse on the bottom of my frame rail right above the drain while I was inspecting the undercarriage halfway through my oil change last night.
MY_FRAME_IS_RUSTY is offline   Reply With QuoteReply With Quote
aluminum , drain , drains , grommet , hose
Coolant drain and fill. Block drain plugs. lj4r 4th Gen T4Rs 2 11-24-2018 07:11 PM
King Coilover Rebuild question. Non extended to extended possible? mAtTyGlaz 5th gen T4Rs 7 01-15-2018 01:31 PM
Should I drain or add some? nissanh 3rd gen T4Rs 11 11-29-2016 04:09 PM
A/c drain mod Toyota4runnerguy 5th gen T4Rs 8 06-25-2015 01:44 PM
AC drain? Crashnrondo 3rd gen T4Rs 4 03-09-2014 04:03 PM
