Old 08-27-2019, 02:00 PM #16
Arv Arv is offline
Arv is on a distinguished road
Arv Arv is offline
Energy part numbers I found: Note that I have stock end links on a 2000.
9.8105 end link bushings and washers 8 each, i"m assuming you only need a set for front and rear.
9.5156 rear swaybar bushings with Zerk
9.5161 front swaybar busings with Zerk
Does anyone have the OEM swaybar bushing part numbers in case I go that route.
Arv is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 02:01 PM #17
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
You should be ok as long as you lube the poly bushings.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 02:07 PM #18
Arv Arv is offline
Arv Arv is offline
I've had poly before on a Honda with Tokico adj coilovers. proper set-up. The car handled great but the squeaking was embarrassing going over humps!
Old 08-27-2019, 08:02 PM #19
Arv Arv is offline
Arv Arv is offline
Ok, bit the bullet and got the ES sb bushings with Zerks and also the end link bushings.
9.5156 rear swaybar bushings with Zerk 3/4"
9.5161 front swaybar bushings with Zerk 1"
I guess its oks to use Lucas Marine grease on these, this is what they recommend mini-grease-gun-combo | Mini Zerk Grease Gun with Automotive Friendly Grease
Now the question is fitment and additional hardware. I read a post saying that you have to file the rear bracket a bit because the holes are not close enough. How about the front? Are they a direct fit?
Also that you need some washers as the holes on the brackets are wider/bigger? Are the washers for 12mm or 14mm bolts?
Thanks
Old 08-29-2019, 02:43 PM #20
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
After a few days of research, I concluded that Lucas Blue Marine grease was the best easily obtained grease for my new Prothane poly sway bar bushings (after using up the laughably tiny grease packet that came with them). The biggest thing to worry about is wash-out, and since it's marine grease, it's highly water resistant. I just made sure to pump a metric shit-ton in, and it's been pushing a year and still no squeaks.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 02:49 PM #21
Arv Arv is offline
Arv Arv is offline
I'm actually expecting an email back from Lucas, the rep said he will check with their chemist. I asked which is better the marine or X-tra heavy duty (one is polyurea the other lithium based) for poly bushings. But I'm with ya with washout, I think the marine would be better. Now I wish I can just use my Sta-lube marine grease but not sure how an ALuminum complex based grease would do to the bushings.
brakes , bushings , mod , rear , suspension
Replacing Front Shocks... Should I Replace Springs Too?.2 JMat 3rd gen T4Rs 7 12-21-2018 01:22 PM
Replacing XREAS with Shocks - Which coil springs for a smooth ride? meltdowner 4th Gen T4Rs 6 09-26-2018 01:26 AM
Replacing front shocks/springs sugjavier 3rd gen T4Rs 0 07-28-2017 03:29 PM
Replacing shocks on 99 LTD, do rear springs too? elmorekevin1 3rd gen T4Rs 1 09-13-2010 04:04 PM
What additional parts, if any, are needed when replacing shocks and springs? jamess 3rd gen T4Rs 2 05-18-2010 12:45 PM
