Old 08-27-2019, 11:21 AM #1
Ifirefight's Avatar
Ifirefight Ifirefight is offline
Ifirefight is on a distinguished road
Ifirefight's Avatar
High pitched beep AND more
01, brake,ABS,VSC,Trac lights are on, NO check engine light, No codes..checked just in case. High pitched beeping noise also. It did it a few weeks ago once, then was fine. No work has been done to vehicle recently. Any suggestions what to look at first? Thanks
Ifirefight is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 12:40 PM #2
rightyouareken rightyouareken is offline
rightyouareken will become famous soon enough
Sounds like the ABS system warning alarm possibly. There are numerous things that can trigger this alarm and ABS codes.
Has the brake pedal felt normal? How are you attempting to pull the code? It's possible that your scan tool isn't able to pull the ABS system codes...I am not sure if that's accessible via standard OBDII or not. Your first order of business is finding what codes are being stored. There must be some if the lights/buzzer is on.
Here's the section from the factory service manual about ABS fault codes. 96-02 Toyota 4Runner Factory Service Repair Manual
2002 4Runner SR5 4WD
2018 VW Golf R
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 02:32 PM #3
audiness's Avatar
audiness audiness is offline
audiness is on a distinguished road
audiness's Avatar
Most likely your brake hydro motor has failed
audiness is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 03:02 PM #4
It's possible, but that causes the brake pedal to feel hard as a rock, since it's not getting any power assist. He's not reporting anything like that.
2018 VW Golf R
1998 BMW M3/4/5
Old 08-27-2019, 03:20 PM #5
thennen's Avatar
thennen thennen is offline
thennen has a spectacular aura about thennen has a spectacular aura about thennen has a spectacular aura about
thennen's Avatar
Years ago I had a rear shock come loose (wore through is more like it) on the passenger side of my 2001. It eventually popped out, and the 1/4"-diameter end of what remained of the stud nailed the ABS wire dead-center. I almost couldn't believe it when I saw it. I think it actually took a day or two for it to get through the insulation and cause brake and ABS lights to come on. Until that happened, it just felt a little more springy, according to my wife who was the DD. I don't remember if there were any accompanying beeps.
A month or two ago, someone else on the forum described almost the exact same failure, but I don't recall all their symptoms. But maybe something related to the ABS cabling?
thennen is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 04:37 PM #6
Ifirefight's Avatar
Ifirefight's Avatar
I
I have the factory service manual. You are correct, I am using a OBDII code reader, so maybe thatís why I get no code. Pedal feels normal, fluid is at the proper level, never an issue with any type of fluid leaks. I started it again to move it into the garage and the lights and beeping went off..very hard to diagnose an intermittent problem.
Old 08-27-2019, 04:53 PM #7
Ifirefight's Avatar
Ifirefight's Avatar
According to the manufacturer of my scan tool, it will read ABS codes.. maybe I didnít hit the correct button...will wait and see if it does it again and try to read the ABS codes.
Old 08-27-2019, 06:02 PM #8
I came across these instructions for pulling ABS codes, but haven't tried them myself:
Unable to Diagnose ABS light
2018 VW Golf R
1998 BMW M3/4/5
fine , high , iphone , pitched , work
Front High Pitched Metallic Whine @ High Speeds (video) JWaldz 3rd gen T4Rs 1 01-13-2016 08:22 PM
High pitched noise from rear? chloeno 4th Gen T4Rs 2 08-31-2010 11:48 AM
Help- High Pitched Sound 08UrbnRunnr 4th Gen T4Rs 6 11-08-2008 11:36 PM
High pitched noise at WOT NolanRey 3rd gen T4Rs 9 09-11-2008 11:32 PM
High pitched noise ???? bzizziv8 4th Gen T4Rs 3 03-08-2006 01:35 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
