Old 08-30-2019, 12:30 PM #1
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Post What all should I replace when replacing CV axles?
As the title says, what all should I replace while swapping the CV axles? I'm still running on the originals from what I can tell and I feel like the moment I start hitting trails, the 19 year old joints are going to explode. Haha
Are there any seals or other items I should swap at the same time?
Old 08-30-2019, 01:12 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
When I did mine, I replaced the axle seals and lower ball joints.
This is what on file for the numbers of the seals
Front Differential CV joint Seal (Driver Side) 90311-47027
Front Differential CV joint Seal (Passenger Side) 90311-47013
I used moog lower ball joints so i don't have the part numbers for those :-(
Last edited by brillo_76; 08-30-2019 at 01:17 PM. Reason: Wanted to add part numbers ;-)
Old 08-30-2019, 02:26 PM #3
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
i swapped my rebuilds in when doing the TBU and forgot to order seals and dust covers. Guessing with new ones you dont have to worry about this
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 03:44 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Great thought on the Caliper dust covers, But don't you have to pull the hub out of the bearings to change those on the Front? Unless you are referring to the CV joint dust covers, I couldn't find those or buy them when I changed mine out. :-{
Old 08-30-2019, 03:53 PM #5
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
LBJ's
LCA bushings
7.5 ECGS clamshell bushing
Outer diff/cv seals
Drain and fill front diff
Since it will be on jackstands,
Poly rack bushings.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 04:18 PM #6
phattyduck phattyduck is online now
They won't explode unless you are doing some really crazy stuff. The boots may leak and that's it.
If you are swapping CVs, it is reasonable to do the seals. Consider new OEM lower ball joints since you have to halfway remove them when doing the axles.
Personally, I don't think you will need to do axles at all. I'd do new lower ball joints before axles...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 08-30-2019, 07:54 PM #7
jross20's Avatar
jross20's Avatar
OEM Lower ball joints was one of the first things I had done.
So you think the cv's are okay? I just don't want to break anything haha.
Do you know the part numbers for those seals? I will go ahead and order some as spares.
Old 08-30-2019, 09:12 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Looks like it's a mistake to use moog ball joints on the 3rd gen runners due to suspension design. Glad to now know this as I have a fleet of them and be checking mine every 5k for play.
Old 08-31-2019, 11:07 AM #9
jross20's Avatar
jross20's Avatar
Originally Posted by 2TH4IST View Post
LBJ's
LCA bushings
Outer diff/cv seals
Poly rack bushings.
Okay, I've not done some of those. I'll add them to the list!
axles , haha , joints , replace , year
replacing front axles - which seals should I replace? moodle 4th Gen T4Rs 4 08-04-2017 01:11 PM
To replace C.V. axles or just reband? JLRSR5 4th Gen T4Rs 6 01-31-2017 10:42 PM
Replacing CV axles bobdod04 4th Gen T4Rs 0 05-14-2013 06:26 PM
Replacing CV Axles loko ino Classic T4Rs 14 12-04-2012 05:10 PM
Should I replace the CV Axles???? Jeff T 4th Gen T4Rs 6 12-10-2011 05:04 AM
