Old 08-28-2019, 02:28 PM #1
TheExplorer's Avatar
TheExplorer TheExplorer is offline
TheExplorer is on a distinguished road
Cannot find battery drain - any suggestions?
I have a 2002 4runner SR5 and I have a 1.26 amp drain on my battery which I can not find.
On the negative side of the battery I used an amp meter and pulled all the fuses one by one in the engine compartment and under the dash and there was no change in the draw.
Is there by chance another fuse box that I am not seeing?
Any other suggestions?
Thanks
Get out and explore the outdoors as much as possible
TheExplorer is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 02:41 PM #2
nissanh nissanh is offline
Did you check the alternator draw? remove the wire plug and 12V live wire (10 mm bolt) from the alternator and check again. Remove the battery ground post before you remove the 12V ground wire mounted on the alternator.
Old 08-28-2019, 03:06 PM #3
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Thanks
You should have seen a change when removing the fuse for the radio since it's constantly drawing.
Here's the best video for finding a parasitic drain.
YouTube
MStudt is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 03:19 PM #4
baja1 baja1 is offline
baja1 is on a distinguished road
my parasitic draw ended up being a back window de-fogger, pulling the fuse didn't clear it.....pulling the relay did.
baja1 is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 04:44 PM #5
Thanks, I just did this and this was not the issue
Old 08-28-2019, 04:45 PM #6
I have not pulled any relays yet so I guess that is next.
Old 08-28-2019, 05:16 PM #7
pokeyman pokeyman is offline
pokeyman is on a distinguished road
Like Nissanh said check the alternator
pokeyman is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 05:56 PM #8
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
EDIT: I can't read, you checked them all. But yes, some circuits use relays, not fuses.
326WHP 347TQ
Old 08-28-2019, 06:28 PM #9
Just finished doing this and no luck. I will go through them all again tomorrow in case I missed something, (fuses, relays, alt)
Thanks
Old 08-28-2019, 06:44 PM #10
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
I'm no expert, just trying to think of the odd thing that could fail that might not be fused in the usual fashion, and I thought about trailer circuitry. I found this - "there's a splitter box in the drivers side panel back in the cargo area" and this - "towing converter relay (81985-35010) behind the left side rear cargo panel". These guys may be referring to the same part. Perhaps try disconnecting any wiring for that?
Plus, any aftermarket add-ons that may have failed?
thennen is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 12:37 AM #11
Update: I have not found/solved the problem yet however I was out tonight and I noticed that my 3rd eye brake light was on even though the truck was turned off.
When I pushed the brake pedal it went out and the two main brain lights came on. When I released the brake pedal the 3rd eye came back on. So for now I have diconnected the light.
At least I know where I am to look now.
Old 08-29-2019, 07:22 AM #12
tvpierce's Avatar
tvpierce tvpierce is offline
tvpierce will become famous soon enough
tvpierce's Avatar
Check the wire harness that goes to the rear hatch.
For reference, here's a thread discussing it: (Go to page 2 for pics. My problem was different, but the cause could be the same -- it's a somewhat common issue as these rigs get up in age.)
'02 T4R Rear Defrost
tvpierce is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 01:24 PM #13
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
I agree, check the harness, specifically that rubber boot.
I had 2 wires break cleanly there (effectively killing my rear window and wipers), and a 3rd wire had stripping insulation and was shorting, which was causing my 3rd brake light to go crazy (and actually caused a CEL).
I just spliced in 3 new wires and it solved the problem. Took me maybe 30 minutes during a lunch break.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 08:15 PM #14
Thank you very much, this was the first place that I looked and well the picture speaks for itself, now to repair it which should be straight forward.
https://scontent.fyvr3-1.fna.fbcdn.n...2c&oe=5E10307E
Old 08-30-2019, 09:40 PM #15
All fixed, thanks everyone for your help. See picture in link for the issue
amp , battery , drain , find , suggestions
Battery Drain zcostilla 3rd gen T4Rs 7 08-16-2019 08:16 PM
Help tracking down battery drain TXRick 3rd gen T4Rs 22 06-14-2015 07:34 PM
Battery drain! Help! gbrunin 3rd gen T4Rs 8 04-10-2015 09:28 PM
Battery drain vicar 3rd gen T4Rs 2 08-09-2014 11:18 PM
'98 Battery Drain jranger35 3rd gen T4Rs 12 03-11-2008 08:10 PM
