Old 07-13-2020, 09:39 PM #1
itskohler's Avatar
itskohler itskohler is offline
itskohler is on a distinguished road
itskohler's Avatar
What to install with new shocks and springs, and other noob questions!
Good afternoon all! I have some 5th gen stock springs (non-TRDPro) coming my way soon, and intend to do the springs and shocks (as well as OTREs, LBJs, and 265 75/r16 tires) at the same time. I'm kicking the idea around of doing the sway bushings as well, but undecided on that right now.
What else should i be doing while I have all four corners i the air? Bump stops maybe? I've never done a lift on a vehicle this old, but have lowered an early 80s VW truck (I should have never sold that thing!).
My rig will spend the majority of its life on concrete, and maybe the occasional trail, but nothing too gnarly. Are Billy 5100's overkill? KYB seems nice for the price, but I don't want to swap it all in just to regret it.
Lastly, shot in the dark, does anyone have pictures of their rig with 5th gen springs and 32's?
98 Limited - 2010 Triumph Daytona - 2017 GTI
itskohler is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 12:48 AM #2
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about
Real Name: Ryan
You might consider doing steering rack bushings while you're at it.
Made a big difference for me in "on road performance."
I'd look at your tie rods as well.
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited - Supercharged
2001 BMW M5
1999 BMW Z3M Roadster
2020 Super White ORP
Ryance39 is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 09:14 AM #3
itskohler's Avatar
itskohler's Avatar
Should have mentioned that I've done the rack bushings. The outer tie rods are on the list to be done with the LBJs. Shop is saying the rack is bad, but the only leaks I see are left over oil from the leaky valve covers. That said I'll be doing the rack in the future, and no sense buying $150 inner tie rods when a new rack is a little more and comes with them installed.
Old 07-14-2020, 10:06 AM #4
Built4Run Built4Run is offline
Real Name: Jacob Jensen
Built4Run is on a distinguished road
Yup Check upper lower ball joints I’d go with oem BJ’s I’ve seen a lot of cheap parts store ball joints fail and personally almost had a catastrophe with my whole family in the car. Also check wheel bearings and UCA & LCA BUSHINGS
get an alignment...
Built4Run is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 01:53 PM #5
OEM lower ball joints. Make sure all other alignment-related parts are in good shape while you are in there.
Here's 265/70-17 (equivalent to 265/75-16) with 4th gen rear springs and 10mm trim packers in the rear. Front is OEM springs on 5100's (up a couple perches, but with bumper/skids), so likely a bit lower than 5th gen springs.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-14-2020, 01:57 PM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
are they saying rack is bad because of a leak, and do you see the leak in loss of fluid. true like you said maybe oil is from old vc leak.
slop in system can be innner tie rods. also the steering rack guide is know to get some slop and people replace with the newer style. MTBT has a video on it I think. ALso there are several threads on it.
sure you can get a rebuilt rack for 150 like shop says....but do research on that too on the forums as some say the rebuilt racks are junk, and many dont come wiht the inner tie rod ends installed....at least thats what Ive read..have not needed one myself
Old 07-14-2020, 04:23 PM #7
XJeepguy's Avatar
XJeepguy XJeepguy is offline
Real Name: Jeff
XJeepguy is on a distinguished road
XJeepguy's Avatar
Real Name: Jeff
I'd do your CV boots while you are in everything . If they're old they'll rip apart lifting things , IMO .
1998 4Runner 4WD Ltd
XJeepguy is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 04:27 PM #8
itskohler's Avatar
itskohler's Avatar
get an alignment...
Ill be checking the UBJs, and have some OEM LBJs in a box with a bunch of other random parts. The bushings are in my sights as well.
Looks good! Getting my excited to get it all on there!
Old 07-14-2020, 04:36 PM #9
itskohler's Avatar
itskohler's Avatar
Ill keep that in mind. I dont have any shops around me other than a dealership unfortunately. Honestly Ill probably just pay them to do it.
Good call. I'm thinking I should just replace the CVs all together. Ill grab some boots just incase they look pretty bad to hold me over. Never done boots. Need any special tools for the straps?
Old 07-14-2020, 04:43 PM #10
XJeepguy's Avatar
Real Name: Jeff
XJeepguy's Avatar
Real Name: Jeff
I'm a big fan of re-booting the OEM CV's , I think they are a far superior product then your average AutoZone etc... CV's . Providing they are in good condition. If you go aftermarket hang onto your OEM's ( this is providing no has changed them out already )
Boots aren't hard to do , YouTube is your buddy there .
Good Luck .
Old 07-14-2020, 04:53 PM #11
itskohler's Avatar
itskohler's Avatar
Good Luck .
Cool man, looking into it now! Thanks!
5th , gen , rig , shocks , springs
Lift questions. More than just springs and shocks 08runnertjb 5th gen T4Rs 3 03-14-2016 02:01 PM
Shop Shocks & Springs Install Stuck CAPS 4th Gen T4Rs 15 03-21-2014 04:25 PM
CB Radio Install Noob Questions SAC-CA-Runner 3rd gen T4Rs 11 04-11-2013 01:38 AM
Bout to install FJ shocks/springs mrpanic7 4th Gen T4Rs 16 02-03-2012 02:31 PM
Questions about FJ springs and shocks ATXsmoke-a-thon 4th Gen T4Rs 8 09-16-2009 03:19 PM
