Old 08-29-2019, 03:55 AM #1
eurasiaoverland eurasiaoverland is offline
eurasiaoverland is on a distinguished road
Front window rattle - from new?
96 3rd Gen
If my front windows are partly wound down and I close the door normally, I get a horrible slapping sound from the window glass rattling inside the rubber weatherstrip runs.
I've got the door apart and everything inside is fine, the regulator looks like new, the channels which hold the weatherstrip inside the door are perfect, the bolts holding the regulator rail to the window are tight. I'm pretty certain the weatherstrip is the culprit - I can see the gap for the glass is far wider than on the rear doors (which sound great when they close, and the windows slide up and down like silk).
Before I shell out for new rubber, I just wanted to be sure that they don't rattle from new - does anyone have a 3rd Gen whose front windows don't rattle?
Thanks
EO
1993 Hilux 2L diesel manual - in storage.
1996 Hilux Surf 3RZ-FE manual - overland vehicle (and rolling restoration).
1989 Landcruiser BJ60 - undergoing full restoration and engine transplant.
Over 250,000 kilometres around Eurasia in Toyota trucks: http://eurasiaoverland.com/
eurasiaoverland is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 12:43 PM #2
lockedlex's Avatar
lockedlex lockedlex is offline
lockedlex will become famous soon enough
lockedlex's Avatar
I've read about this before. There's a post here where someone fixed it by pulling out that rubber track, adding something next to it, then putting it back into the door frame.
This effectively narrows that gap in the rubber track and reduces vibrations when open.
PS my 2000 doesn't rattle, but my 94 and 95 2nd gens did with the front windows open.
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
lockedlex is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 03:39 PM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
I just went out to the parking lot to check.
No rattle. The glass for sure has some movement to it but there is NO audible rattle. Oddly, my passenger side has more wobble than the drivers. This is with the window down about 3 inches.
The glass is quite unsupported in this position. Only the rear has much support. The rear doors are supported front and back in any position.
Hope this helps.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 07:21 PM #4
JMat's Avatar
JMat JMat is offline
JMat will become famous soon enough
JMat's Avatar
Here's a link to a post I read from 4Runner4Leon: Window rattle fix - cheap and easy!
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
JMat is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 12:22 AM #5
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
Yes indeed . The fix works flawlessly, I can drive with partially lowered windows and not hear any rattles.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 11:47 AM #6
JessyJ JessyJ is offline
JessyJ is on a distinguished road
Originally Posted by booster15 View Post
I had a similar situation but unfortunately I had to change the window.In general I always try to be carefful with car windows because I had a situation when I had to replace them. I know how much can it cost so now i'm very carefful with them. But despite all my efforts I have small scratches on the windows that irritate me. I found specialists in tempered scratched glass repair. They came and in some hours the windows' glasses were like new.
I'm just looking for a service that can remove a scratch from the door glass. I wonder if this company has valid promo codes?
JessyJ is offline   Reply With QuoteReply With Quote
door , front , inside , weatherstrip , windows
Front passenger side window rattle JeffMerr 4th Gen T4Rs 11 02-28-2022 04:46 PM
Window Glass Rattle Fix lightfreak 4th Gen T4Rs 2 08-02-2018 07:09 PM
Window Rattle Fix Castle_runner 3rd gen T4Rs 1 02-12-2018 09:06 PM
Rear Window Rattle Sherwood4Runner 3rd gen T4Rs 11 06-21-2016 01:36 AM
