Old 08-30-2019, 09:50 AM #1
eurasiaoverland eurasiaoverland is offline
eurasiaoverland is on a distinguished road
Can I remove front side windows without removing weatherstrip?
Hi Guys
96 3rd Gen - can I safely remove the glass from the front windows (I have the door cards off) without pulling out the rubber weatherstrip in the door which seals around the edges of the glass?
Thanks
EO
1993 Hilux 2L diesel manual - in storage.
1996 Hilux Surf 3RZ-FE manual - overland vehicle (and rolling restoration).
1989 Landcruiser BJ60 - undergoing full restoration and engine transplant.
Over 250,000 kilometres around Eurasia in Toyota trucks: http://eurasiaoverland.com/
eurasiaoverland is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 10:52 AM #2
nissanh nissanh is offline
Yes, you can. Unbolt the two 10 mm bolts that holds the glass to the window mechanism. Lower the glass into the door and lift the glass from the rear end (closer to the door latch)and remove. Installation is the exact opposite.
Old 08-30-2019, 12:12 PM #3
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
As Nissanh said, yes you can pull it out without removing the trim: I pulled the trim which made it mildly easier (and I was able to clean the hell out of it)
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
door , front , glass , remove , weatherstrip
How to remove front passenger-side swaybar mount? Heyduke 3rd gen T4Rs 7 06-29-2018 12:38 PM
WTK: Source for weatherstrip or solution for hard to roll up and down windows? PRdubi Classic T4Rs 8 12-15-2012 09:25 PM
Anybody found a way to remove passenger side headlight assembly without removing the Bonin 5th gen T4Rs 1 03-29-2012 01:21 PM
How to remove Rear windows in '95 Offie Classic T4Rs 2 07-29-2008 09:14 AM
Removing front side pillars statman24 4th Gen T4Rs 3 04-03-2008 07:03 PM
