08-30-2019, 05:46 PM
Transmission dipstick issue
Hey all
So working on slowly fixing up my 1997 SR5 and noticed that when I went to check the transmission fluid, the dipstick reading was way over the 'hot' mark with the vehicle cold/not driven. Putting the dipstick back in was very difficult, it hangs up on the last 1/3 of the length.
I was at a pick and pull today and there were 2 1999 T4Rs there both with the same 5VZFE engine so I pulled both the transmission dipsticks on them out and noticed they were significantly shorter than the dipstick in my truck. I bought one of the dipsticks and brought it home, put it in my truck and it was still difficult to push in the last maybe 3 inches but the level was between the cold and hot zones
I have no idea if my truck had a new transmission put on and also do not know if the 1999 models had a different trans (both were SR5) but I am wondering if my truck has the wrong dipstick... if not, then it seems that the trans is way overfilled
The picture below has my existing dipstick on top and the one I got from the junkyard on the bottom
Anybody have any ideas on this? I really do not want to have an over or under-filled transmission and looking at the fluid, it really needs a drain/flush and refill (may even tackle dropping the pan and changing the filter to see how much metal is on the magnets)
Thanks!
08-30-2019, 05:54 PM
There are 2 different dipsticks for these models. If I remember correctly, it had to do with the Fed vs CA emissions thing (but I could be wrong). Regardless, the (correct for my vehicle) dipstick is Extremely difficult to get back in place. The one that came with the truck was bent in a hundred spots which made it even harder, though a brand new OEM replacement wasn't much easier. Common thread here in the forums, and there's info about which of the 2 your specific truck will need/use. Obviously, using the wrong one would be bad....
08-30-2019, 06:39 PM
Real Name: Jon
Real Name: Jon
Are the dip stick tubes the same length on the 4 runners?
Mine are fun to get in. If you look you notice that the dipstick tube is in 2 pieces. They love to hang up and are super easy to bend. I have a couple that look like they been through a war. I had a spare off my parts mobile and it even got bent to being worthless. :[ all mine look like your longer one.
08-31-2019, 11:26 AM
I would say the dipstick you took out of your truck is the correct one. They are notorious for hanging up in the tube when installing and are always bent from people forcing them. You just have to wiggle, jiggle and rotate them to make them go in. I'm assuming you checked it with the engine running. If not, that's why it read over full. If so, it is over full.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
09-02-2019, 12:02 PM
dipstick length
I pulled one to have an extra..and noticed the difference in mine also...my truck is 4wd...the one I pulled wasn't..maybe that is the factor here...the senior pros on this site should clarify if possible.
09-03-2019, 02:34 PM
Real Name: 3 Bears
Real Name: 3 Bears
yes the dipstick is a pain to put in, until you figure out how to have the correct orientation to start, twist and wiggle going in and hold your tongue just right
now that I have learned the "trick" its not an issue, but still harder than most can.
( I too had to get a new one after getting my 4runner as the original was all bent up making it even harder to install, I just went to dealer with my vin and old one and ordered correct new one)
2002 tundra ac v8 4wd
1969 kharmann ghia
09-03-2019, 02:39 PM
2WD dipstick is different from 4WD dipstick. The 2WD pan is smaller/shorter and so the dipstick is shorter to accommodate. The Cali vs. Fed emissions thing may also be a factor, but it is more about routing of the tube down to the pan around different catalytic converters.
AT fluid level is to be checked with the engine idling in Park. The correct final measurement can only be made with engine idling and the trans fluid at operating temperature (154*-176*F) after cycling through each gear (P-R-N-D-2-1-2-D-N-R-P) on a level surface.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
09-03-2019, 03:01 PM
I picked up a new one at my local dealer dealer about six months and even with the VIN they gave me the wrong one(shorter). When I went back the parts guy just said "Oh... It'll be this one then" and blamed it on a mid model year change. My '98 was manufactured in July of 1998. Seems like they often don't know either.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
09-17-2019, 11:26 AM
Oh, that is really good to know! I was actually almost sure that something is wrong with mine ) Now I think I may be don't need to buy a new one ). Thanks!
07-06-2024, 08:26 PM
I have a 2000 3.4 4WD with automatic I just bought. It's as cherry as they get in original condition with 110,000 miles. I was confounded by the tranny dip stick to no end. I took a wild guess it was hopelessly bent out of shape by the previous owner. Ordered a new one from Bighorn Toyota in Glenwood Springs, Colorado. I could have sworn they told me thirty something dollars for it. When I gt there it was like $64. Unbelievable. I was just dumbfounded it had the same exact problem. I could swear there's some sort of obstruction. After reading this thread looks like an extremely common problem. I cut the old one off and tossed it and just used the plug end until the new one got here. Looks like a total waste of money. I did not try to force it. I put the old plug back in until I figure out what to do next. It seems crazy it's this difficult to get back in.
07-07-2024, 09:33 AM
if it doesn't want to go in by pushing on it while helping the stick down the tube with a 2nd hand, remove and turn 180* and try again, works every time, I have mine marked so I know which direction the handle should be facing.
07-07-2024, 11:40 AM
Real Name: 3 Bears
Real Name: 3 Bears
agree, i have to two hand both my 4runner and my yota
1969 kharmann ghia
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
