Old 03-10-2020, 09:41 AM #151
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh Drew. That is just too much. :] I guess that's one way to look at it.
Is the weather up north starting to switch to spring?
brillo_76 is online now   Reply With QuoteReply With Quote
Old 03-23-2020, 05:33 PM #152
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
What to do when your cat floor insulator rusts off at nut comnections.
Old 03-23-2020, 05:40 PM #153
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well you have a few options Here. You can replace with new or used one.
Which still isnt going create an issue as your nuts and studs the nuts are really rusty and would most likely snapped if removed.
So what I did was clean the threads up with a tap. M6 x 1.0. Then place washers over the rusted bolt.l with one washer to tighten down with a new nut.
Cleaned it up and painted with high temp paint.
Old 03-23-2020, 05:41 PM #154
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This is the end result bolted on. I shot the bolts washers with high temp paint as well.
Old 04-13-2020, 06:13 PM #155
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Tetanus 1 needed a patch on the frame. This is what the bottom and inside rail looked like.
Old 04-13-2020, 06:15 PM #156
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
So I cut the bottom out and descaler the inside. No picture descaled it seem. As you can see this spot wasnt a complete disaster.
Old 04-13-2020, 06:19 PM #157
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Then welded the plates in the inside and sealed the frame back up. It also looks like I didnt take a photo of other side of the frame rail. I did this a week or so ago. Over a weekend.
Old 05-21-2020, 07:25 PM #158
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes Brillo broke down and bought a plasma cutter. I should have bought one a few years ago as they really do speed up cutting steel. So much less damage then torches and loving every minute of using it.
Old 05-22-2020, 12:34 PM #159
19963.4lsr5 19963.4lsr5 is online now
It makes a much cleaner cut. I used one on the 86 CJ7
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 05-22-2020, 01:11 PM #160
Drew76 Drew76 is offline
Drew76 is on a distinguished road
[QUOTE=brillo_76;3493025]Yes Brillo broke down and bought a plasma cutter. I should have bought one a few years ago as they really do speed up cutting steel. So much less damage then torches and loving every minute of using it.
Been wanting one of these, what brand/model did you get? Have you tested it to see if it really can cut the advertised thickness?
Drew76 is offline   Reply With QuoteReply With Quote
Old 05-22-2020, 01:27 PM #161
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
[QUOTE=Drew76;3493391]
I am only on 110v at the moment that will cut up to 1/8 think. I dont have any 5/8 to try let. Being I just got it last week. It's going to take me time to give an honest review. This is a 110 / 240 volt cutter. So I pleased with it thus far. The cart it's on has crappy wheels on it . This one is a Titanium 110/240 plasma cutter from harbor freight. Being I dont weld commercially and use it on occasion. I believe it will suit my needs. On 110 it will go 15 to 16 amp. I doubt it let you goto 30 amp. On 220 it will go to 45 amps. So you can cut anything on a 4 runner with a 115v plug...;)
Old 05-24-2020, 06:51 PM #162
Cool, let us know how it works out. I've heard that the advertised rated cut thickness may not live up to real world scenarios, not specific to Harbor Freight machines just all in General.
Old 05-24-2020, 06:59 PM #163
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well it just saved my a pile of time. I changed the rear control arms in the rear and a bolt w as seized. So on 15 Amps and on 110. It melted the nut off. Then I sliced the bolt off about 1/4 from flush and ground it a little. It all fell apart and didnt melt the bushing out of the control arm like a torch would. Nor did it melt my bracket any..
Old 05-24-2020, 07:00 PM #164
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Tetanus 1 just got 4 new control arms today. The one was already installed when I snapped the photo..Brillos Builds-20200524_132205-jpg
Old 05-24-2020, 08:33 PM #165
Nice. Yeah I usually use oxy acetylene torch especially on exhaust stuff or on things like diff/transfer drain plugs that get rounded off i just weld a nut on.
chassis , frame , repairs , rigs , road
MORE 3RZ builds....... ralatkins 3rd gen T4Rs 21 10-28-2022 12:39 PM
Trailer Builds Okki 5th gen T4Rs 6 12-15-2019 09:11 PM
Vehicle Builds Victory 4x4 Victory4x4 4 06-19-2019 08:44 AM
5th Gen Pre-Runner builds? PeoplecallmeIan 5th gen T4Rs 0 03-14-2018 04:34 PM
