Old 05-25-2020, 11:09 AM #166
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by Drew76 View Post
Nice. Yeah I usually use oxy acetylene torch especially on exhaust stuff or on things like diff/transfer drain plugs that get rounded off i just weld a nut on.
Yup. I really liked the non damage to my surrounding area. The heat was only were it needed to be.
Old 08-02-2020, 08:47 PM #167
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well. I done a few small projects since May here as it been in the 90s with high humidity which makes it extremely miserable to wear leather and weld..
Anyways here is a 3rd gen transmission crossmember that I replaced the nuts in welded back together and then sealed the steel with rust inhibitor and kb seal.
Old 08-02-2020, 08:47 PM #168
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Looks like a need a photo or 2 what it looks like now. I get that in a day or 2.
Old 08-02-2020, 08:54 PM #169
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Here is a gas tank skid plate I redid for @Last Man Standing . It was Tetanus 1 original with some rot holes and rusty sections. I hope he pleased with it.
Old 08-13-2020, 10:41 PM #170
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Tetanus 1 hitch got descaled and corroseal coating today. The bottom of that hitch was replaced 5 years ago as it was completely rotted away... I descaled with an China freight air descaler then coated it with Corroseal. As you can see the converter was still curing when I took the last photo. For spending its life 21 years in the rust belt. That hitch is extremely solid yet. Granted I dont haul anything heavy on it anyhow.
Old 09-06-2020, 07:18 PM #171
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The hitch even got some Frankenstein bolts on it for fluid film annual coatings
Old 09-06-2020, 07:19 PM #172
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Looks alot better now
Old 09-06-2020, 07:22 PM #173
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Then I started cleaning and resesealing my handmade inner rockers. I add some photos on what it looks after resealed.
Old 09-06-2020, 07:24 PM #174
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I came across my center frame mount getting a little thin. When they go half normal thickness they either need replaced or thicken back up.
Old 09-06-2020, 07:29 PM #175
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This what the frame bracket looks like now. I cut 1/8 inch plate. And welded the plates in to strengthen it. I just need to grind it down and seal it back bracket back up.
Old 09-06-2020, 08:24 PM #176
I got the front drivers side rocker rot I need to deal with in the next year.
Old 09-07-2020, 01:12 AM #177
TheShowtime TheShowtime is offline
TheShowtime is on a distinguished road
Yes Brillo is the best with frame work! Nicest guy also, personally gave me his phone number to help me answer all my questions about rust.
TheShowtime is offline   Reply With QuoteReply With Quote
Old 09-08-2020, 12:38 PM #178
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Maybe my rocker section will help you. Mine no longer existed.
Old 09-08-2020, 12:40 PM #179
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I did get that section all coated in corroseal. I am experimenting with it. This is what that area looks like now. Those body mounts are harder to paint. I going to recoat with a .5 inch brush..
Old 09-20-2020, 06:49 PM #180
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
@RandyBobandy and I are completely stripping my parts rig. I was going to be silly but this is how far we got in about 6 hours or so thus far. So looks like a heater core change on these would be a very big task . We post the occasional photo until this rig is completely all parts..
chassis , frame , repairs , rigs , road
MORE 3RZ builds....... ralatkins 3rd gen T4Rs 21 10-28-2022 12:39 PM
Trailer Builds Okki 5th gen T4Rs 6 12-15-2019 09:11 PM
Vehicle Builds Victory 4x4 Victory4x4 4 06-19-2019 08:44 AM
5th Gen Pre-Runner builds? PeoplecallmeIan 5th gen T4Rs 0 03-14-2018 04:34 PM
