Old 11-14-2020, 06:16 PM #211
brillo_76's Avatar
Real Name: Jon
brillo_76 is a name known to all brillo_76 is a name known to all brillo_76 is a name known to all brillo_76 is a name known to all brillo_76 is a name known to all brillo_76 is a name known to all
brillo_76's Avatar
Real Name: Jon
Why you replace the insert. Careful with the center screw that goes all the through or you loose the little nut..;)
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 11-14-2020, 06:18 PM #212
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
As you can see my paint and FF looked exactly how they did when changed the fenders last year. I was curious how it were would hold up in there and its perfect..
Old 11-14-2020, 06:28 PM #213
Sarki Sarki is offline
Sarki will become famous soon enough
Originally Posted by brillo_76 View Post
$65.00.
Wow, great price.
I found one that was same color and “supposedly” original paint......NOT!
Drove 120 miles only to find a rusty tailgate that had been sprayed at least once, asking price of $250....PASS!
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 06:37 PM #214
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy has a spectacular aura about RandyBobandy has a spectacular aura about
The proper way to repair that antenna is to get one from the parts store that doesn’t really fit, and then glue it in place without hooking it up to the radio, because your significant other says it looks stupid with it missing.
I have NOT done that, but I think that’s how the service manual says to do it
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 10:32 PM #215
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by Sarki View Post
Wow, great price.
I am sure this was repainted However. Eventually I have to paint this one to red. For the condition and price I couldn't go wrong.
Old 11-15-2020, 05:09 PM #216
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Got it all back together and will verify no leaks for a few days before putting the engine skid back on.
Old 11-16-2020, 07:41 PM #217
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Tetanus 1 got a new denso radiator yesterday.
Old 11-16-2020, 08:37 PM #218
should have put a big all aluminum rad on there, the extra cooling capacity will be necessary when we bolt a huge ebay turbo on there making like 50psi of boost
Old 11-16-2020, 09:50 PM #219
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Or that external tundra coolers we were looking into at that pick and pull.
Old 11-20-2020, 08:52 PM #220
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Working on my 5 speed frame seal and inner plate project. You can see the frame is decent in this section. I did clean and corroseal the frame. Now I can weld new plates in and reseal the frame back upon this area..
Old 11-20-2020, 09:30 PM #221
HiLife HiLife is offline
HiLife has a spectacular aura about HiLife has a spectacular aura about
@RandyBobandy and I hit a local pick and pull. I got doors for the wife's sienna van and a set of tocuma lock out hub assembly for our 3td gens .
Out of luck for the Tundra calipers that fit the 16 in wheels. However, we did ok..;)
Good score! I got the opposite going on here. Got 231's at the yards here, but having a hard time sourcing locking taco hubs, ha
Old 11-20-2020, 09:42 PM #222
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Its amazing how different areas and environments effect part supplies. Our interiors and drivetrain head south and the chassis rot up. All chassis parts are coveted here and extremely plentiful in the south.
Old 11-21-2020, 10:26 AM #223
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The rust inhibitor dried now it's time to cut and weld plates.
Old 11-21-2020, 01:12 PM #224
I know you mentioned you use corroseal, have you found that it's better than the rest? Or, basically all rust converters are all the same and, corroseal is just cost effective? The one I've used in the past is Skyflo Ospho.
Old 11-21-2020, 02:06 PM #225
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Corroseal is decent. However it's best to coat with something else after the corroseal is dry. Seemeds to be a working as a rust inhibitor. Just not as a top coat. Ospho been around a long time. I sure it's a grear product as well.
Corroseal is rated pretty high. I perfer it because its non toxic.
Inside the frame here I coat it all with corroseal then when welded shut I super coat everything inside with FF. Any of the rust prevention solutions should work fine as the frame is hole free when I done.
chassis , frame , repairs , rigs , road
Trailer Builds Okki 5th gen T4Rs 6 12-15-2019 09:11 PM
Vehicle Builds Victory 4x4 Victory4x4 4 06-19-2019 08:44 AM
5th Gen Pre-Runner builds? PeoplecallmeIan 5th gen T4Rs 0 03-14-2018 04:34 PM
MORE 3RZ builds....... ralatkins 3rd gen T4Rs 20 01-26-2013 04:15 PM
