I believe the ones I got fit 3rd gens and the other 199mm rotor smaller wide tundra calipers.
I suspect the larger ones would use a different bleeder. Arent they the 230mm rotors and calipers that only fit 17 rims?
I am thinking those ones are the calipers folks are having issues with as are master cylinders are not designed for that large caliper. Might be too much fluid volume and give the folks spongy petal.
The caliper that is just wider and the same diameter as the original ones make the most sense to me as the best replacement for the standard caliper.
I pulled mine off a 2002 sequoia with 16 inch rims on purpose as all I am after are rotors no longer warping and I will be happy.
I got a way to go before my larger calipers go on. I was just glad to find a set for $40.00. One was a remfg one. The other I will sandblast it and put a caliper rebuild kit in it so I wont have any issues with them. [ I hope]
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
