Old 07-30-2022, 09:51 PM #541
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Gave the patches a coat on the inside of the hatch. This seals off oxygen. If you seal off oxygen, it can't rust. I ran fiberglass resin along the bottom seam and up the side seam as well.
Old 08-12-2022, 09:50 PM #542
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Got my ebay license bezel in. I finished putting the rear door back together. That was fun getting the window back in and bolted back onto the regulator. I greased the tracks up. All in all the rear door hatch rust and Track repair went alright. I just worked on it here and there.
Old 08-18-2022, 09:30 PM #543
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I did not know our rear door hatch wiring harness is in 2 pieces. Basically, the plugs that plug into the body harness in the rig runs down the pillar then to 2 plugs on your hatch plate. The other harness is for the internals and plugs into to plugs next to your hatch plate. I never realized that these are two pieces and wanted to share in case others didn't know this. This is out of my parts rear door hatch which I will sale pieces of wires so others can patch their wires in that rear door hatch boot. I did forget to take some photos of the 2 parts. :-(
Old 08-19-2022, 08:46 PM #544
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The 2 seperate rear door wire harnesses
Old 08-22-2022, 10:21 PM #545
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
What it looks like when you have an ac leak when you have die in it.
I even tried new o rings. Looks to like I may need new Toyota o rings and 2 lines replaced.
You can see the sight glass line is the line itself.
I am debating on the low pressure line. I put 2 ac o rings in with the same result.
Could it be just the aftermarket ac o rings?
On that particular line, I don't see the toyota o ring part number. The rest I do. I am just mad at myself for not just getting the replacement o rings from Toyota. As at least one of thise leaks would not be there.
Old 09-24-2022, 10:58 AM #546
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well.. Yesterday I was supposed to have my car lift installed. That I ordered in March April. Delivered July 20th.. Had my spot in thr garage all cleaned out and waited for the installer appointment. Then 8 am the fun began. By 8:30 the fun stopped... Benpak shipped me the wrong one......
Old 09-24-2022, 12:00 PM #547
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
That’s disappointing for sure especially after waiting all that time.
But…….it’s worth all the trouble, love my HD-9!
Brillos Builds-a4cc8c57-6b0d-44aa-824f-0e1fa7d1b4c4-jpeg  Brillos Builds-fd4e44da-03b3-4783-852e-c139d0503ce1-jpeg
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 06:31 PM #548
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ah a 4 post. Mine is a 2 post. They just sent me the short one. It only goes up to 6 ft.. I am 6 3 my brother is 6 6 so I ordered the tallest 2 post bend pak its beams are 13 to 14 ft high. This one beams are 12 2 inchs so not going to work for what we want. :-)
Old 09-24-2022, 08:21 PM #549
Whether going 2 post or 4 post, the best part is no more laying on your back on a nasty cold concrete slab!
Having the lift was a game changer for me. The 4post serves me well and with the sliding RJ-45 jack I can pretty much do any needed repairs.
Hoping you get yours soon as it will change your life.
2002 SR5 Sport 4WD
Old 09-24-2022, 08:59 PM #550
jsnppp jsnppp is offline
jsnppp will become famous soon enough
So jealous of a lift! 2 or 4, I'd be fine with it. I have a standard garage and it just won't do any good.
Brillo, I've used generic green o rings without a problem. One thing I did find out is that you can over torque the junctions. I think the rule of thumb is finger tight and then 90 degrees. Less than you think. This was on different cars however, not a 4runner.
~ Jason
2002 4Runner 4wd SR5 Sport Edition
+ many other cars
jsnppp is offline   Reply With QuoteReply With Quote
Old 09-25-2022, 12:46 PM #551
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well that could be an over torque issue. I do have the new line as its leaking at the sight glass through the line plus I bought a few sets of the oem Toyota o rings. (I just need to change it yet)
I mostly use a super short ratchet its like 4 inches long 3/8 drive so I don't over torque them as aluminum with steel bolts is mostly 13 to 15 ft/lbs max.
After 33 years of working on Toyota's, I just can't stand crawling on the floor anymore. I was proud of myself I didn't get super angry or yell at anyone for extreme mess up. Granted, I was and still am bummed about it. :-)
Old 09-25-2022, 04:39 PM #552
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well I replaced Shitbox high line with the sight glass. The 10mm bolt on thr drier seem to fit snugger with the new oem lines. I pag oiled the o rings. Luckily the evap box side [17mm 19mm] came right apart. I paged oil the pressure switch [27mm, 19mm]. Pulled a replacement line clip to secure the line properly.
I replaced the low line o ring on the Condenser seemed to be snugger as well. The o rings seem to be the sane diameter as the green one. Except the oem one seems to have more girth so hopefully my 2 front leaks are sealed.
When I charged up the ac again. I watched the sight glass. Being it's crystal clear you could see what's going on.
I watched when the refrigerate hit the system. Then when it got enough to start to work. Went cloudy because it was way to low. Then when it was getting close you only see a few bubbles in the site glass. Then it goes clear. No bubbles nothing. My guess is that is the proper amount refrigerate for the state to function properly.
Old 09-25-2022, 04:45 PM #553
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This is what a ac system that is low in refrigerate. This is Tetanus 1 cycling as its low on refrigerate.
Old 09-30-2022, 06:40 PM #554
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Advance sold the lift that i have sitting here. The good news that they ave have 4 in stock and will be shipping it shortly. So with some luck in a week or 2.
Old 10-19-2022, 08:51 PM #555
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
A big day. I need to put a heat shield in and put the power to it but at least it standing
chassis , frame , repairs , rigs , road
MORE 3RZ builds....... ralatkins 3rd gen T4Rs 21 10-28-2022 12:39 PM
Trailer Builds Okki 5th gen T4Rs 6 12-15-2019 09:11 PM
Vehicle Builds Victory 4x4 Victory4x4 4 06-19-2019 08:44 AM
5th Gen Pre-Runner builds? PeoplecallmeIan 5th gen T4Rs 0 03-14-2018 04:34 PM
