Old 02-06-2023, 04:48 PM #586
Colorado buff Colorado buff is offline
Colorado buff will become famous soon enough
Beautiful job on the Tacoma frame. Shocking that it missed a recall? Your gain though.
Colorado buff is offline   Reply With QuoteReply With Quote
Old 02-06-2023, 06:48 PM #587
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Why thank you. My builds are mostly frame repairs. I figured maybe a few will enjoy these posts. I know it's not a 3rd gen but the front of the frame is very similar .
Old 02-06-2023, 07:24 PM #588
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
@Yeti2k3 and I are working on the tacuma bed. We have a few holes and a crossmember repair. We have to put replacement inside the crossmember and stiffen the one up again.
Old 02-07-2023, 12:15 AM #589
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Tetanus 1 got an alignment today as it hit 290k miles.
So my power steering was humming and moaning. I pump out the fluid. Verified the screen was clean and it was. So I swapped it one I pulled from the pick and pull. Nice and quiet now. I wonder if these are worth rebuilding? I have 2 or 3 that can be rebuilt or set back as cores.
Old 02-07-2023, 04:46 PM #590
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
Man I really need to get after mine soon >< It's only whinny at full lock on the steering so I'm pretty sure it's the screen as well as old fluid.
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 02-07-2023, 05:24 PM #591
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well mine is whiny all the time.. The used replacement isnt as bad but not quiet either.. I probably end up rebuilding a few of these as they really should be quiet all the time.
Old 02-12-2023, 05:44 PM #592
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
@Yeti2k3 and I working on the bed. You can see how I fix nuts inside things. We weld nuts to washers then weld the Washers to 1/8 plates . Drill and plug weld the plates to their proper location.
Its very hard to weld to 20 gauge that's rusty or rusted away. Yes we need to grind a little but making very good progress. Just need rebuild the fender wells. Then seal the seal ending up raptor lining both sides of the bed. The bed sides will be our next project. I believe the bed sides will be painted red.
Old 02-12-2023, 06:25 PM #593
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Looks like the frame repair is coming right along!
Sent from my SM-T220 using Tapatalk
Old 02-12-2023, 06:55 PM #594
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Nice work Jon.
Always get inspired checking out your updates and watching the progress.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 02-12-2023, 10:12 PM #595
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This is a better photos of welded in nuts. I welded 18 gauge in the sides for strength. I put grease in the nuts to keep them cooler, and at the Sametime, keep weld splatter out of the threads too.
Old 02-19-2023, 09:13 AM #596
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
How l do you fix the o2 sensor rusty studs and nuts issues? Why you use 8mm 25mm x1.25 bolts stainless with a flanged nut and lock washer all stainless... you screw the bolt in snug then spring the nut down to hold the sensor in place.
Old 03-12-2023, 07:40 PM #597
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Tetanus1 just rolled over 290k
Old 03-22-2023, 09:36 AM #598
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Captive studs
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 03-22-2023, 11:52 AM #599
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by octanejunkie View Post
Captive studs
Those are an option as well. I just like how I could snug the O2 down on the sensor yet still just unscrew these bolts a few years down the road here..
Old 04-25-2023, 10:52 PM #600
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The Tacoma bed is coming along. @Yeti2k3 did a great job on bed repairs. I have been working on a neighbors 2001 Jeep Liberty replacing the rockers. I'm going to be gluing the outers rockers on the Jeep soon.
chassis , frame , repairs , rigs , road
MORE 3RZ builds....... ralatkins 3rd gen T4Rs 21 10-28-2022 12:39 PM
Trailer Builds Okki 5th gen T4Rs 6 12-15-2019 09:11 PM
Vehicle Builds Victory 4x4 Victory4x4 4 06-19-2019 08:44 AM
5th Gen Pre-Runner builds? PeoplecallmeIan 5th gen T4Rs 0 03-14-2018 04:34 PM
