So I just welded the brackets on for outboarding shocks. Tetanus1 which was thrown together for something to drive in 2015 with 215k as experimental plating just seeing how long things last in the rust belt. Now sits at 291k and my first vehicle plated when I couldn't even weld yet. I can now say that if you just weld plates on. You have 5 to 8 years. I am going to have to redo things to make this last longer.
Granted, I only going to 300k then I either sell this rig to South America only if the price is good. If not, I may make it a 3rd parts mobile.
Now, if you clean treat and paint metal this increases years.
I am actually quite surprised this frame lasted this long without major treatments.
This particular one isn't worth a frame swap.
This would have lasted longer if I coated the inside of the frame with heavily rust inhibitors. But I needed a control..
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
