Originally Posted by mesooohoppy
sure, but bondo can flake/chip off or just decide it doesnt want to adhear to rust anymore and then your back to square one. this isnt the right way to do it. its a temp fix at best. bondo sucks.
I dont use bondo. However, you guys are correct but keep in mind, this is Tetanus 1. You can see the shape of the panels. I mostly use API metal reinforced body puddy. This one is a work beater. This isn't my 5 speed nor my 2001 sport. It's really my experimental rig. I practice things on it. As it was the first to get replacement steel rockers.
as this is how you improve.
I know a perminate fix is to replace the panels. This one was extremely bad when it fell into my possession. This is an example on how you can fill holes. I should have mentioned that. I did state I was driving it and continued to drive it through the entire process.
The body filler has fiberglass screen all through it so I doubt it will fall off or flake. I also put metal in were the bolts went and molded them in as this rot was very intensive. My inside of those panels are dry. So I got the holes sealed and that was the intention. :]
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
