Originally Posted by HiLife
I know you mentioned you use corroseal, have you found that it's better than the rest? Or, basically all rust converters are all the same and, corroseal is just cost effective? The one I've used in the past is Skyflo Ospho.
Corroseal is decent. However it's best to coat with something else after the corroseal is dry. Seemeds to be a working as a rust inhibitor. Just not as a top coat. Ospho been around a long time. I sure it's a grear product as well.
Corroseal is rated pretty high. I perfer it because its non toxic.
Inside the frame here I coat it all with corroseal then when welded shut I super coat everything inside with FF. Any of the rust prevention solutions should work fine as the frame is hole free when I done.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
