What it looks like when you have an ac leak when you have die in it.
I even tried new o rings. Looks to like I may need new Toyota o rings and 2 lines replaced.
You can see the sight glass line is the line itself.
I am debating on the low pressure line. I put 2 ac o rings in with the same result.
Could it be just the aftermarket ac o rings?
On that particular line, I don't see the toyota o ring part number. The rest I do. I am just mad at myself for not just getting the replacement o rings from Toyota. As at least one of thise leaks would not be there.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
