Old 05-19-2023, 07:34 PM #616
jlwatts jlwatts is offline
jlwatts is on a distinguished road
I just bought a 2000 4Runner that needs the rocker panels replaced bad so I appreciate all the documenting you did because I’m gonna need all the help I can get!
jlwatts is offline   Reply With QuoteReply With Quote
Old 05-20-2023, 09:40 AM #617
Originally Posted by brillo_76 View Post
Well. I need to drop to a 2 x1 inch flat bar. When I cut my rocker panel to size it up. I was a 1/2 inch lower on the pinch weld. So this is what the I got done today. Just seeing how things would fit. My daughters cat Rosie even was helping some. :] I am getting closer to getting this passenger side buttoned back up.
I verify the 2 x 1 will work good. Then start rebuilding the inner rocker. Weld the tube in. Then weld the outer rocker in. Finish by building the front and rear back in again.
I plan on doing this exact thing with my rocker panels as my insides are no good. What exactly is the square tubing welded too when you cut out the inside rocker panels? I cant really tell by the picture and until I actually cut mine out I'm having a hard time picturing it.
Old 05-20-2023, 11:24 AM #618
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes that's for ones the the inner metal is rotted out.
I need to finish removing the spot welds in my junk yard set. So I can send the inner rockers to Canada to be templated.
The tube inside is for strength..To tie the body mounts back together
Old 05-20-2023, 10:48 PM #619
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Here is what it looks like with the outer rocker removed. I started removing the outer rocker to get down the inner rocker for Templating. .
Old 05-20-2023, 10:49 PM #620
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Here is the front seat bolt that trips or rusts out. Well you can at see the bottom of this 2 thin crossmember
Old 05-26-2023, 08:26 AM #621
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Why you do not use harbor freight cutting wheels. A chunk stuck in a garage door... :/ Imagine if that is your skull
Old 05-26-2023, 09:45 PM #622
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Next to the last post of the Tacoma that 2 DIY did. Primered and painted. It's been the project for a while.
Old 05-26-2023, 10:13 PM #623
Speedy's Avatar
Speedy Speedy is offline
Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough
Speedy's Avatar
Looking good. What color is that?
Speedy is offline   Reply With QuoteReply With Quote
Old 05-26-2023, 10:21 PM #624
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Red. [Lol] let's ask @Yeti2k3 .... in a few days I can get the actual paint code.
Old 05-26-2023, 11:28 PM #625
Yeti2k3 Yeti2k3 is offline
Real Name: Joe
Yeti2k3 is on a distinguished road
Real Name: Joe
Color code 3L5 Toyota Radiant Red!
Yeti2k3 is offline   Reply With QuoteReply With Quote
Old 05-31-2023, 03:32 PM #626
I feel like I'm the only one that keeps the stock guard on my grinder. Still could have chunks fly off, but at least I'm on the 'safe' side of the guard! I know that you need to remove or adjust it sometimes, but it isn't hard to do.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-31-2023, 08:31 PM #627
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes. I remove all of them and use better wheels. I found 2 bricks of harbor freight cutting wheels that i am trying to use up. I stepped on that one and has to just do a little slice.. we found that piece days later..
Granted, you really do have to be careful of the cutting wheels and wire wheels. Keep out of the line of fire. That's mostly how I use them.
Old 06-01-2023, 11:54 AM #628
Speedy's Avatar
Speedy's Avatar
My grinder has the guard on it.
Old 06-01-2023, 01:15 PM #629
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
They always get my way on the small ones. The air ones done have them. My 4 inch grinder does
Old 06-04-2023, 05:07 PM #630
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Welding nuts on broken lower ball joint bolts. Thankfully got to save that one. Got the busted bolt out.
chassis , frame , repairs , rigs , road
MORE 3RZ builds....... ralatkins 3rd gen T4Rs 21 10-28-2022 12:39 PM
Trailer Builds Okki 5th gen T4Rs 6 12-15-2019 09:11 PM
Vehicle Builds Victory 4x4 Victory4x4 4 06-19-2019 08:44 AM
5th Gen Pre-Runner builds? PeoplecallmeIan 5th gen T4Rs 0 03-14-2018 04:34 PM
