Old 09-01-2019, 03:32 PM #1
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Bilstein 6112 clip position and lift heights
I didn't see any real world info, maybe others will search and keep this thread current. This is needed because what Bilstein lists for lift height/clip position simply isn't true.
At clip positions 6/7 I had 2.5" lift (claimed 1.6")
At clip positions 3/4 I have a 1.75" lift (claimed 0.7")
This is on a stock 99, no extra weight up front and 2" lift in the back with OME 906 springs. I ran about 100 miles, with 20 of those as fairly high speed washboard, before taking the initial measurement. No clue why I'm seeing numbers So far off from Bilsteins specs. But I'm not the only one..
https://www.toyota-4runner.org/2783844-post22468.html
Looks like another stock limited, but claiming clip positions 6/7 and a 1.9" lift.
Just be warned, you'll likely need to pull the shocks and springs after the initial install to get the right height. I'd advise starting 1 clip lower than they suggest unless you have a plate bumper + winch.
Brian. is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 10:07 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
@Brian. What was your fender to hub measurement prior to lift? Which 6112's did you use, 4Runner or Tundra?
Old 09-03-2019, 10:28 AM #3
Brian.'s Avatar
Brian.'s Avatar
Fender height before lift was 20.5" all around, now just on either side of 23" (rear higher, front lower). I used the 4runner 6112's, the 47-258624 kit.
Old 09-03-2019, 06:48 PM #4
AL B. AL B. is offline
AL B. is on a distinguished road
I love my 6112’s
• 2001 LTD 4WD • Bilstein 6112’s up front • Tundra Bilstein 5100 + OME 890 in the rear ig: socal4runna
AL B. is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 08:19 PM #5
Benfica Benfica is offline
Benfica is on a distinguished road
Originally Posted by AL B. View Post
I love my 6112’s
Al B.,
How do you like the Tundra 5100 and 890 coils? What clips did you put the 6112 on? I'm going to go with the 6112 up front for a 2inch lift, just trying decide what to put on the back.
Any hub to fender measurements?
Benfica is offline   Reply With QuoteReply With Quote
Old 04-15-2020, 03:11 PM #6
gbb gbb is offline
gbb is on a distinguished road
gbb gbb is offline
Bumping this thread as Brian and I were having a conversation about 6112 clip settings in a different thread. It might be worth updating the original post in this thread with the following information.
Originally Posted by Brian. View Post
Good grief, that's my biggest complaint. I have no clue what perch I ended up with because I had to change it 3 times. I was aiming for just Slightly taller than stock on a '99, minimal positive "rake". 3/4 I think, maybe that's where I started.
I honestly got so fed up with changing the heights that I simply quit. Not Exactly where I wanted it but heck if I'm changing it again for the small difference.
I wanted the 2.5" body for the extra oil (takes longer over rough terrain for fade ~ I was a suspension tech in decades gone Way by so sometimes I let my theoretical wants over-rule common sense). Makes complete sense that the Valving is the same as that is 100% reliant upon the spring rate.
I dug up some old posts that I found during my 6112 research. Below are some of the perch settings and corresponding ride heights that I found. Perch settings are listed with the driver side first.
9/8 Setting:
- 808Waterman: Level, but no additional lift info. OME 890 + 5100 in the rear.
8/7 Setting:
- BikeDestroyer: 8/7. Front 1/4" higher than rear. OME 906 + 5100s in the back. Appears to be running a rear bumper.
- bigcap76: 8/7. Front 1/2" higher than rear.. OME 906 + 5160s in the rear. Doesn't appear to be running a rear bumper.
- repo: 2.5" all around. OME 906 + 10mm rear spacer + 5100s in the rear.
- fixxor: 1.9". OME 906 + 5100 rear
- fixxor: 2" in the front. 2.5" in the rear. OME 890 + 5100 in the rear.
7/6 Setting:
- Brian: 2.5" of lift. OME 906 + 5160 in the rear
- jmferg: 1.9" of lift.
6/5 Setting:
- bigcap76: pre lift measurement from hub center to fender was 20". After setting on 6/5 setting, 2.25" of lift achieved
- Mint: 5100 Rear w/ ACDelco 45h2131 (99' Talls) & OME 10mm Rear Spacers... Totals for ~ 1.5" lift all around
6/4 Setting:
- georunner_sjc: Tasteful amount of lift. Front bumper with Eibach 1" Pro Lift springs (E30-82-006-05-02) with 5160s in the rear.
4/3 Setting:
- Brian: 1.75" of lift. Stock '99 with no extra weight. "Fender height before lift was 20.5" all around, now just on either side of 23" (rear higher, front lower)." OME 906 + 5160 in the rear.
gbb is offline   Reply With QuoteReply With Quote
Old 04-15-2020, 05:48 PM #7
Brian.'s Avatar
Brian.'s Avatar
Sheesh, I guess I should search my own posts then. :P
Just measured 20.75 on fronts and 22 rear drivers, 22.5 rear passenger (hub center to LTD fender flares). I've put about 2k miles on the 4runner since that first post, so there's a good bit of settling.
Might have to look at a 10mm spacer for the drivers side rear, wonder how much different the measurement is when I'm not 100% full on fuel.
Old 04-16-2020, 07:56 AM #8
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Just noticed that the recommended clip positions are offset by an additional space for OE rear coils vs 2" lift. Wonder why that is.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 08:53 PM #9
Drew76 Drew76 is offline
Drew76 is on a distinguished road
I know this is an old thread, just wondering if anyone has any updated info. About to install my 6112's and OME 906 rear springs. I have 5100's in the rear about 3 yrs old I have 1.5" daystar spacers front and rear currently, not on OEM suspension mind you, have crappy Monroe shocks/struts in front with the daystars, been on about 4.5 yrs, (40 000 miles, less on the 5100's) have Moog replacement rear springs same age as the Monroes with the 5100's,I'll be ditching all but the 5100's and my airlift bags in the rear, my current measurements from my 2000 Limited centre hub to flare are:
Front Driver: 21 7/8"
Front Passenger: 22 3/16"
Rear Driver: 22 1/2"
Rear Passenger: 22 7/8"
So, the OME rears should get rid of the Taco lean out back and offsetting the height settings on the 6112's should take care of the front, I'm looking for a little rake 1/4" to 1/2" from Back to Front, assuming my rear height will increase by 1/2" after settling to about 23" to 23 1/4" as the 906 should be a 2" lift spring, what would anyone suggest I set the fronts to? Reading above there seemed to be a big drop in ride height from Brian's original measurements in the first post to a few months later after 2k miles, I'm thinking 7/6 or 6/5 on the fronts, any thoughts?
Drew76 is offline   Reply With QuoteReply With Quote
Old 11-13-2021, 01:44 PM #10
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
I set mine to the 2” setting up front. Same setup as you except 5160 rears.
No lean no sag, no anything. Just a nice even lift all the way around. Pair with some Duro bumps and life is good.
The Bilstein chart is posted a couple of posts back. I just followed that with new Monroe top hats. Those have the inner bushing already permanently mounted, took me a minute to figure that one out. Also, most of the individual redi rod style harbor freight strut compressors that are out there don’t work well on the 6112. You can get it, but it’s a bit of a fight because it binds.
There is also a driver and the passenger side on your 2906 springs.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 11-13-2021, 02:39 PM #11
Thanks! So, by the 2" Setting you mean #8/7 circlip location and with 2906 springs you're level all around?
I do have the Monroe top hats as well.
Old 11-13-2021, 02:44 PM #12
In the included instructions they mention that they are aware that aftermarket lift springs like OME compensate for the side to side lean compared to OEM.
Old 11-20-2021, 11:47 PM #13
Romeo1's Avatar
Romeo1's Avatar
@Drew76
I just followed the instructions for their clip settings up front. They recommended 2” lift coils for the setup.
Given Bilsteins culture of engineering, I felt it was a disservice to not follow their recommendations.
Old 03-14-2023, 12:27 PM #14
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
6112 6-Driver/5-Pass C-Clip Lift Gain
Id like to know what lift people are experiencing using the 6 driver/5 pass c- clip setting? Im currently using the 7 driver/ 6 pass setting and the trucks level with the 906/60028 OME combo in back. Im looking for a bit of rake since i have no weight up front..
Cheers..
jrm is offline   Reply With QuoteReply With Quote
Old 03-14-2023, 07:48 PM #15
Cheers..
I changed mine from 7/6 to 6/5, let it settle then got an alignment, I like a little rake too and I have about an inch.
Rear 22 1/2"
Front 21 1/2"
Been like this for close to a year.
bilstein , clip , lift , positions , stock
Bilstein 6112 Lift Heights Kamalani Mahie 5th gen T4Rs 25 04-12-2022 07:07 PM
Bilstein 6112 with King 14x3x650# - which clip setting? jasxn 5th gen T4Rs 2 03-13-2018 12:14 PM
Alignment issues after Bilstein 6112 lift. Help! carrera0to60 5th gen T4Rs 27 08-07-2016 11:48 AM
Toytec Bilstein 5100 coilover 3" setting...C-clip position?? Ebbsnflows 5th gen T4Rs 4 03-26-2015 05:30 PM
