Old 12-28-2019, 01:32 PM #16
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I have experience with rebooting CV axles with both OEM and the ORS boots. The ORS boots require you to reuse the wide part of the original boot end that secures to the tulip joint. Stretching that ORS boot over the OEM boot end was a serious fight. Hopefully the CJV boots with the adapter ring are easier than the ORS boots to get in place on the joint.
Old 12-28-2019, 02:04 PM #17
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
It requires a bit of work to force the boot over the adapter but it wasn't that bad. I found doing the boot stretch mod with the old CV boot (as done in one of your videos) to be a lot more work and significantly harder to deal with stretching the snap ring over the shaft to install and remove it. Plus it was way way messier to deal with as well. After like 1k miles the boot still ended up splitting. Perhaps I stretched mine just a bit too much and perhaps it'll work a good portion of time but it wasn't working for me.
To me the only right solution is to use these CVJ / ORS boots. I believe they are actually just a CV boot from a specific Porsche but they work great and I haven't had any problems with mine since installing them.
APhelps is offline   Reply With QuoteReply With Quote
boot , boots , guys , kit , lift
Inner CV boot split at edge, can someone suggest a split boot repair kit? sakoluvr 3rd gen T4Rs 7 10-17-2018 02:55 PM
Upper ball joint boot leak—replace UBJs or just boot kit? starclassic 3rd gen T4Rs 4 07-31-2016 02:50 AM
What boot do I need? Wakko 3rd gen T4Rs 2 07-19-2016 11:30 AM
Inner Tie Rod Boot; Where to Buy? Kirk_B 3rd gen T4Rs 0 07-26-2015 06:07 PM
Rear shocks: boot up or boot down? mrlouie 3rd gen T4Rs 4 08-22-2011 10:27 AM
