Old 09-02-2019, 10:44 AM #16
Tacomabob Tacomabob is offline
Real Name: Bob
Tacomabob is on a distinguished road
Real Name: Bob
Loos like you are extremely lucky you were going as slow as you were, could have been a lot worse.
Tacomabob is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 11:03 AM #17
PatrickStapler PatrickStapler is offline
PatrickStapler is on a distinguished road
Thanks for the well wishes guys...I do feel lucky from the aspect of the circumstances in which it happened.
BTW...sorry if I posted this in the wrong forum. I just noticed there are different forums for model year.
Kind Regards,
Patrick
PatrickStapler is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 11:07 AM #18
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
You've had water intrusion in the cv joint.
Probably due to a torn boot.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 12:09 PM #19
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Originally Posted by PatrickStapler View Post
...Fortunately, I was on a downtown street only going 25-30MPH.
Glad you're not hurt, Patrick.
Originally Posted by brillo_76 View Post
The ball joints are a weak spot in the 3rd Gen 4runners.
Correct! Worst and most dangerous thing Toyota has done with the 4Runner, I think.
Patrick,
There's a thread about it. My explanation why YOUR generation is within that thread here:
https://www.toyota-4runner.org/3175578-post169.html
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 12:40 PM #20
So it appears these separated from the sockets. The studs are both completely in tact.
Kind Regards,
Patrick
Old 09-02-2019, 12:56 PM #21
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
What’s weird is the the road I was traveling was as flat as could be. No bumps. No dips. It just snapped.
The flat bed driver said in his many years of service (and he was old) he had never seen one single Toyota fail in this manner. Leave it to me...
A couple of months ago there was a rash of these getting broken. Then a bunch of guys decided to have some fun and started making a meme about it. Not really funny when it happens to you though. You'll be back up and running in no time. I'm sure you'll do both sides at the same time.
It appears high mileage or rough service will wear these ball joints out and break with little to no warning sometimes like yours did. The check for wear is kinda vague too. The slightest movement in those ball joints means it's time to replace them.
Like others said; it's a weak point in T4R's.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 01:08 PM #22
CV Joint Pliers
Are these the correct pliers?
https://www.amazon.com/gp/product/B0...5NHGNZ61&psc=1
Kind Regards,
Patrick
Old 09-02-2019, 01:12 PM #23
Yes...replacing everything on both sides. I cant risk going down the interstate at higher speeds with my wife or kids in the truck and the other side failing.
Kind Regards,
Patrick
Old 09-02-2019, 02:00 PM #24
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Patrick,
Wouldn't this design flaw be made worst when Folks get the big tires and rims on the rigs as the stresses would be greater on the ball joints. Then factory tire sizes and rims?
Old 09-02-2019, 04:43 PM #25
Sway Bar Bushings
Doubt these were doing much of anything...
Both sway bar end links were limp as a wet noodles.
Kind Regards,
Patrick
Old 09-02-2019, 05:22 PM #26
Torque Specs
So I don’t have a shop manual for this vehicle. Can you guys point me to a document that prescribes all the values for everything on the front suspension?
Kind Regards,
Patrick
Old 09-02-2019, 05:38 PM #27
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
I just did the UCa, LCA, LBJ, steering rack, sway-bar, etc... these are from my notes:
• Cam Adjuster Bolts - 96 ft-lbf
• UBJ torque 80 ft lb
• UCA torque 87 ft lb
• 3 upper shuck nuts torque 47 ftl lb
• Lower Shock Bolt - 101 ft-lbf
• Outer Tie Rod Castle Nut - 67 ft-lbf
• swaybar bushing bracket 19 ft lb
• swaybar end links - 14 ft lb
• ball joint bolts 59 ft lb ~ blue locktite
• Lower Ball Joint Castle Nut - 105 ft-lbf
• Wheel Lug Nuts - 85 ft-lbf
• For Steering Rack:
• Driver side long bolt that goes through cross member - 141 ft-lbf
• Middle Perpendicular Bolt - 123 ft-lbf
• Passenger Side Bracket Bolt and Nut - 123 ft-lbf
But man, there are links to the oem service manual all over, find one and download it to your phone so you Always have it on you. Has saved me too many times to count with different vehicles, and that's only in the past decade.
Brian. is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 06:21 PM #28
Thank you Sir.
Kind Regards,
Patrick
Old 09-02-2019, 09:31 PM #29
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If your CV axles have 300K on them, I would replace them.. Suspension and Sway bar link stabilizer would be if they are bad only. How are the bushings holding up on the upper and and control arms holding up? No play in them?
Old 09-02-2019, 09:33 PM #30
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes those need replaced The stabilizer ends links looking alright or are they shot too?
duh , epic , lower , steering , upper
Toyota of Rock Hill (Rock Hill SC) Service Department = EPIC FAIL! superman3043 Dealers - Your Experience 4 04-11-2016 09:40 AM
Hagarstown MD Toyota service writers -- epic FAIL!!!! vlafrank Dealers - Your Experience 5 06-28-2014 01:29 AM
Epic JEEP fail!!! kmiller8821 Off Topic 6 01-26-2013 12:03 PM
Daystar Epic Fail---Help! kai920 4th Gen T4Rs 4 08-20-2011 09:13 PM
EPIC FAIL, this is why we own Toyotas! the great him 3rd gen T4Rs 16 05-03-2011 12:06 PM
