Old 09-01-2019, 08:50 PM #1
PatrickStapler PatrickStapler is offline
PatrickStapler is on a distinguished road
Epic Fail
So this happened about an hour ago to my ‘99 4WD. Fortunately, I was on a downtown street only going 25-30MPH. No traffic. Lost all brakes and steering...duh!
So what am I looking at here, upper and lower ball joints? Looks like brake line also. Looks like the shocks are also fairly old.
Kind Regards,
Patrick
PatrickStapler is offline   Reply With QuoteReply With Quote
Old 09-01-2019, 09:03 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yup UBJ, LBJ, Brake line, CV Joint. Probably new axle seal I can't tell if the sway bar is still connected or not. Would check the make sure rotor not bend and the brake caliper aright.
How old were the ball Joints on the Rig? How many miles on the ride?
Old 09-01-2019, 09:03 PM #3
eddielasvegas eddielasvegas is offline
Real Name: Eddie
eddielasvegas has a spectacular aura about eddielasvegas has a spectacular aura about
Real Name: Eddie
Man, that is ugly and glad you are okay.
How many miles on your suspension?
Good luck,
Eddie
2001 T4R SR5 - 180k miles and counting.
eddielasvegas is offline   Reply With QuoteReply With Quote
Old 09-01-2019, 11:21 PM #4
TBH, I have no idea the age of the suspension. If I had to guess, I would say everything except the shocks might be OEM. For what I know they could be too. The truck has 315K miles on it.
Kind Regards,
Patrick
Old 09-01-2019, 11:23 PM #5
I have owned it for three years.
Kind Regards,
Patrick
Old 09-01-2019, 11:27 PM #6
What’s weird is the the road I was traveling was as flat as could be. No bumps. No dips. It just snapped.
The flat bed driver said in his many years of service (and he was old) he had never seen one single Toyota fail in this manner. Leave it to me...
Kind Regards,
Patrick
Old 09-02-2019, 12:05 AM #7
White Stripe White Stripe is offline
White Stripe is on a distinguished road
If it was riding ok then I would leave the shocks alone and replace all the ball joints up front.
White Stripe is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 01:20 AM #8
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
From the looks of the tire wear, it appears your camber was way off. When was the last alignment you had on it?
weekendclimber is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 07:31 AM #9
Alignment is less than a year old. I did notice last week that return to center seemed way less than normal. I assumed caster had somehow been decreased. Maybe that was a red flag to this.
Kind Regards,
Patrick
Old 09-02-2019, 08:39 AM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The ball joints are a weak spot in the 3rd Gen 4runners. Need to be checked constantly and replaced with the slightest of wear. However, there isnt any scheduled maintenance in the service manual for them. I would say replace both top and bottom every 100k miles with OEM ones as lots of folks have had failures with aftermarket ones and have them checked at least yearly for signs of wear. My brother lost a lower ball joint in a accord with over 300k years ago. They were mist likely originals too. Glad you not hurt.
Old 09-02-2019, 09:07 AM #11
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
As cheap as they are, I'm replacing them every 25-50 miles.
OP, glad you are okay. You need to swap out all the balls joints, left side too!
Old 09-02-2019, 09:54 AM #12
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
100k I can sorta agree with, 25~50 miles (I'm sure you mean thousand) is way, WAY obsessive for anyone running "stock" heights to roughly +2 lifts. They go 300k miles before most failures in stock setup... no sense just throwing money away.
I imagine age has some impact too. This is 20 years, 194k miles:
OP, hate it for ya but glad it was slow speed and you suffered no injury.
Brian. is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 09:59 AM #13
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
I use to warn others about once a month, if they have over 100K to replace those lower balljoints, no one would ever listen, so I gave up.
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 10:15 AM #14
RS Dude's Avatar
RS Dude RS Dude is offline
RS Dude is on a distinguished road
RS Dude's Avatar
Amazingly, I have never heard of anyone's ball joints failing while going 70MPH! That happening would likely be a death sentence.
'96 T4R SR5 V6 Auto 2WD 329,000 miles
RS Dude is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 10:42 AM #15
Is CV joint lube supposed to look like this? Does this look hurt or can I clean it and reassemble? I have a parts washer.
I’m guessing OEM struts and springs...Japanese Kettering and what appears to be factory paint markings. I guess that’s why it was a bit wobbly at 70MPH.
Kind Regards,
Patrick
duh , epic , lower , steering , upper
Toyota of Rock Hill (Rock Hill SC) Service Department = EPIC FAIL! superman3043 Dealers - Your Experience 4 04-11-2016 09:40 AM
Hagarstown MD Toyota service writers -- epic FAIL!!!! vlafrank Dealers - Your Experience 5 06-28-2014 01:29 AM
Epic JEEP fail!!! kmiller8821 Off Topic 6 01-26-2013 12:03 PM
Daystar Epic Fail---Help! kai920 4th Gen T4Rs 4 08-20-2011 09:13 PM
EPIC FAIL, this is why we own Toyotas! the great him 3rd gen T4Rs 16 05-03-2011 12:06 PM
