Old 09-03-2019, 03:52 AM #31
PatrickStapler PatrickStapler is offline
PatrickStapler is on a distinguished road
Control arms are still tight. No play. Ends links are shot.
Kind Regards,
Patrick
PatrickStapler is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 05:53 AM #32
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Originally Posted by PatrickStapler View Post
So I don’t have a shop manual for this vehicle. Can you guys point me to a document that prescribes all the values for everything on the front suspension?
96-02 Toyota 4Runner Factory Service Repair Manual
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 07:28 AM #33
Mudeprived Mudeprived is offline
Mudeprived is on a distinguished road
With that many miles I would replace every bushing, joint, and shocks. Makes no sense to only replace what is worn because the rest is likely to wear out soon with the miles you have and you end up tearing into it again...and again....and paying for a second or even third alignment.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Mudeprived is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 04:28 PM #34
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
In case you were still wondering, those are OEM Tokico black struts, so most likely the same ones from when the vehicle was manufactured. If you want a smooth ride put the same ones back in. They ride real nice when new with brand new OEM coils.
326WHP 347TQ
Old 09-03-2019, 08:08 PM #35
CV Joint Receiver
Does the little hole in the middle go anywhere or does it stop there?
Kind Regards,
Patrick
Old 09-03-2019, 08:12 PM #36
Wheel Cylinder???
I couldn’t tell where whatever this is, is coming from. I do know this wheel was not participating in the stopping activities.
Kind Regards,
Patrick
Old 09-03-2019, 08:24 PM #37
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
That last one (gooey rear brakes) is a leaking rear axle seal. Usually the cause is a clogged, for a long time, axle breather valve that allows the axle to pressurize and force fluid into the brake drums.
At least that's what I've gathered from a few brief searches, there's better info out there (and Timmy has a video on fixing this issue, needs specialized tools)
Brian. is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 09:09 PM #38
Thank you. It didn't appear to be coming from the wheel cylinder. However, it also didn't smell like rear differential fluid, and it was thin like brake fluid.
Thoughts...Or are you sticking with your original prognosis?
Kind Regards,
Patrick
Old 09-03-2019, 09:46 PM #39
Rear Axle Seal
How do you know which one you need?
Part No.: 90313-48001
SEAL, TYPE K OIL
Part No.: 90310-50001
SEAL, TYPE S OIL
Kind Regards,
Patrick
Old 09-03-2019, 09:54 PM #40
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
pretty common point of failure on 3rd Gen 4Runners and 95.5+ Tacomas
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 10:33 PM #41
2ndhandyotaman's Avatar
2ndhandyotaman 2ndhandyotaman is offline
2ndhandyotaman will become famous soon enough
Classic blown rear axle seals. The expensive part of it is- Toyota's ignorant design where you have to destroy the wheel bearings to get everything apart to GET to the seals.
I saw a 3rd gen today at a muffler shop that had a lower ball joint fail on it, unfortunately the body took a beating from the tire flying off.
I hope that you will be able to get your truck back together and running quickly.
2019 TRD OR. Bone stock and staying that way.
2ndhandyotaman is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 10:53 PM #42
Rear Axle Seal Replacement
Is this video misleading me somehow? I didn't see him touch a wheel bearing to replace the seal.
YouTube
Kind Regards,
Patrick
Old 09-04-2019, 12:40 AM #43
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
The trouble is that once the oil reaches the brake area, it has already passed through your bearings and contaminated/washed out the grease. Whether or not one changes the bearing, they are most likely f-Ed or on the way there.
Watch Tim’s video, read the dr coffee thread. This is not a small or cheap fix. I did mine about a year ago. Better to fix it once and do it properly I think.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 12:48 AM #44
YouTube
That is the proper way to replace the seal but it will most likely leak again. The seals available today are of a different design than the originals.
Your bearing is also contaminated with gear oil due to the seal failure and most likely has it's grease flushed out.
Search for Timmy the Toolman axle seal replacement.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Old 09-04-2019, 01:39 AM #45
Codtay56 Codtay56 is offline
Codtay56 is on a distinguished road
Life
Im glad youre ok and that it didnt happen in a traffic situation!
Codtay56 is offline   Reply With QuoteReply With Quote
duh , epic , lower , steering , upper
Toyota of Rock Hill (Rock Hill SC) Service Department = EPIC FAIL! superman3043 Dealers - Your Experience 4 04-11-2016 09:40 AM
Hagarstown MD Toyota service writers -- epic FAIL!!!! vlafrank Dealers - Your Experience 5 06-28-2014 01:29 AM
Epic JEEP fail!!! kmiller8821 Off Topic 6 01-26-2013 12:03 PM
Daystar Epic Fail---Help! kai920 4th Gen T4Rs 4 08-20-2011 09:13 PM
EPIC FAIL, this is why we own Toyotas! the great him 3rd gen T4Rs 16 05-03-2011 12:06 PM
