09-03-2019, 03:52 AM
#31
Control arms are still tight. No play. Ends links are shot.
Kind Regards,
Patrick
09-03-2019, 05:53 AM
#32
Originally Posted by PatrickStapler
So I don’t have a shop manual for this vehicle. Can you guys point me to a document that prescribes all the values for everything on the front suspension?
96-02 Toyota 4Runner Factory Service Repair Manual
2001 2wd - Daily Driver
09-03-2019, 07:28 AM
#33
With that many miles I would replace every bushing, joint, and shocks. Makes no sense to only replace what is worn because the rest is likely to wear out soon with the miles you have and you end up tearing into it again...and again....and paying for a second or even third alignment.
1999 Limited
265/75/16 AT51's
Bilstein 4600
09-03-2019, 04:28 PM
#34
Real Name: Jerod
Real Name: Jerod
In case you were still wondering, those are OEM Tokico black struts, so most likely the same ones from when the vehicle was manufactured. If you want a smooth ride put the same ones back in. They ride real nice when new with brand new OEM coils.
09-03-2019, 08:08 PM
#35
CV Joint Receiver
Does the little hole in the middle go anywhere or does it stop there?
Kind Regards,
Patrick
09-03-2019, 08:12 PM
#36
Wheel Cylinder???
Kind Regards,
Patrick
09-03-2019, 08:24 PM
#37
That last one (gooey rear brakes) is a leaking rear axle seal. Usually the cause is a clogged, for a long time, axle breather valve that allows the axle to pressurize and force fluid into the brake drums.
At least that's what I've gathered from a few brief searches, there's better info out there (and Timmy has a video on fixing this issue, needs specialized tools)
09-03-2019, 09:09 PM
#38
Thank you. It didn't appear to be coming from the wheel cylinder. However, it also didn't smell like rear differential fluid, and it was thin like brake fluid.
Thoughts...Or are you sticking with your original prognosis?
Kind Regards,
Patrick
09-03-2019, 09:46 PM
#39
Rear Axle Seal
How do you know which one you need?
Part No.: 90313-48001
SEAL, TYPE K OIL
Part No.: 90310-50001
SEAL, TYPE S OIL
Kind Regards,
Patrick
09-03-2019, 09:54 PM
#40
pretty common point of failure on 3rd Gen 4Runners and 95.5+ Tacomas
1994 4Runner AKA: Project Recycle
@503dropzone on IG
09-03-2019, 10:33 PM
#41
Classic blown rear axle seals. The expensive part of it is- Toyota's ignorant design where you have to destroy the wheel bearings to get everything apart to GET to the seals.
I saw a 3rd gen today at a muffler shop that had a lower ball joint fail on it, unfortunately the body took a beating from the tire flying off.
I hope that you will be able to get your truck back together and running quickly.
'99 Limited, 225K miles, 3.4/automatic, multi-mode, e-locker, broken sunroof, no DRL's. 265-75-16 Hankook Dynapro ATM. New Moog rear springs, KYB Monomax F&R.
09-03-2019, 10:53 PM
#42
Rear Axle Seal Replacement
Is this video misleading me somehow? I didn't see him touch a wheel bearing to replace the seal.
YouTube
Kind Regards,
Patrick
09-04-2019, 12:40 AM
#43
The trouble is that once the oil reaches the brake area, it has already passed through your bearings and contaminated/washed out the grease. Whether or not one changes the bearing, they are most likely f-Ed or on the way there.
Watch Tim’s video, read the dr coffee thread. This is not a small or cheap fix. I did mine about a year ago. Better to fix it once and do it properly I think.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
09-04-2019, 12:48 AM
#44
YouTube
That is the proper way to replace the seal but it will most likely leak again. The seals available today are of a different design than the originals.
Your bearing is also contaminated with gear oil due to the seal failure and most likely has it's grease flushed out.
Search for Timmy the Toolman axle seal replacement.
1999 Limited
265/75/16 AT51's
Bilstein 4600
09-04-2019, 01:39 AM
#45
Life
Im glad youre ok and that it didnt happen in a traffic situation!
