Old 09-14-2019, 03:40 PM #1
Supermoney Supermoney is offline
Supermoney is on a distinguished road
New Tundra Bilstein 5100s - perch spacing the same?
Hi guys, as most of you know Bilstein updated the tundra 5100 we all used.
Old Part #: 24-188265
New Part #: 24-261425
To the people that have used both versions, or have been able to compare them side by side, are the perch settings identical? Beside the 5th, as I know that has slightly changed.
I know most people ran the 2nd / 3rd perch on these, is it the same for the new ones?
Thanks
2001 Toyota 4Runner SR5 Sport
Imperial Jade Mica
231mm Tundra Brakes
5100 Bilstein / TRD / OME 890 3" Lift
285/75/16 BFG KO2s
Supermoney is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 10:11 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thanks
From wheelersoffroad.com:
"6/2/17 NOTE: 24-188265 has been superseded by 24-261425. The only difference we see is that the 261425's top clip groove is slightly lower than the -188265 (which will yield a little less lift on the top groove) and the -261425 comes with some bump stop spacers (big flat washers)."
Old 09-16-2019, 08:22 PM #3
CT135 CT135 is offline
CT135 will become famous soon enough
Are you using the Tundra 5100's because of the added notches for lift tweaking or for different purposes? Upgrading soon and curious.
CT135 is offline   Reply With QuoteReply With Quote
part , people , perch , side , tundra
On The 3rd Perch Of Bilstein My Tundra Coils Gave To Me Yoter 3rd gen T4Rs 8 04-26-2016 12:05 PM
Bilstein 5100s with Eibach or TRD Tundra? atalarico 3rd gen T4Rs 23 08-17-2015 12:21 PM
which perch/top spacer on tundra 5100s/eibach thaemcee2 3rd gen T4Rs 27 06-29-2015 11:09 AM
tundra or tacoma bilstein 5100s freshley 3rd gen T4Rs 18 01-02-2015 04:38 PM
Tundra Bilstein 5100s on 4Runner don't fit? Slusher Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-29-2013 12:06 AM
