Old 09-01-2019, 09:33 PM #1
BamaDrewski BamaDrewski is offline
BamaDrewski will become famous soon enough
Re-upholstered Leather Seats + Seat Heaters
I have been piecing together parts for the past few months and ordered leather seat replacement upholstery and seat pad from US Autonation on Ebay. Had to order the OE seat back foam from McGeorge (least expensive) and they (USPS or McGeorge) lost the first shipment and had to send a replacement via FedEx.
I purchased a carbon fiber seat heater kit from Ebay and took my time to install everything correctly. REALLY IMPRESSED with the way everything turned out. Only sad thing is the crappy lumbar support (even though I tested it with the covers off) still does not work. Very poor design by Toyota.
PROS: The seats seem to sit “higher” as the new foam is firmer.
CONS: Takes a lot of time and effort to get everything right but better than paying an upholstery shop to do it at $1,000-$1500 per seat. Pictures will be posted later……
BamaDrewski is offline   Reply With QuoteReply With Quote
Old 09-01-2019, 10:21 PM #2
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Would really like to see and read more
plcfcng is offline   Reply With QuoteReply With Quote
Old 09-01-2019, 10:42 PM #3
Attaching some pics....
Re-upholstered Leather Seats + Seat Heaters-seat-back-1-jpg  Re-upholstered Leather Seats + Seat Heaters-seat-bottom-1-jpg  Re-upholstered Leather Seats + Seat Heaters-seat-heater-switch-1-jpg
Old 09-02-2019, 08:59 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Nice job. The seats look great and I need to do a few sets. I want to put heaters in as well. Thank you for sharing :]
Old 09-02-2019, 10:23 AM #5
If you take your time (and there are some awesome "how-to" videos on YouTube) it won;t be hard at all. Get some hog ring pliers or use zip ties. Zip ties make it easier. ONE THING: when you disassemble your old seats, keep the metal rods and re-use them in the new upholstery covers. You need them to fasten the cover to the seat with zips or hog rings.
Old 09-02-2019, 12:40 PM #6
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
Metal zip ties work extremely well, hog rings are great if you can get the pliers to work. The pliers are quite expensive though and a bit of a bear to use unless you have nice ones.
APhelps is offline   Reply With QuoteReply With Quote
Old 09-07-2019, 09:28 PM #7
U used zip ties to get the connections in place and then used hog rings to make sure they stayed. Easier than wrestling down the connection with finicky hog ring pliers and hog rings flying all over the place....
Old 06-23-2020, 03:40 PM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
After a 7 hour round trip drive on Saturday I realize that I'm in desperate need of better seats. My stock seats are absolutely torture after an hour!
How are the new seat foams holding up and feeling? Can you compare old vs new foams for me? Is it worth the investment to refoam and reupholster or would you go a different route?
Old 06-23-2020, 09:12 PM #9
In response to your post and inquiry, I could not be happier!!!!! The seats are holding up (no sagging, shrinking, compression) as well as the leather seat covers from Ebay. I put in seat heaters (carbon fiber from ebay) and when it was cold, they worked like a champ. I would HIGHLY recommend this. It is expensive to gather the parts and time consuming to do the work but at the end of the day, doing yourself will save you a bunch of $$$$$$! If you are like me and love your rig and never plan to get rid of it, I would recommend this.
Old 06-23-2020, 10:38 PM #10
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
I had both fronts recovered in pleather with all new foam, bottoms and backs. 2 stage foam, majority is firm underneath and a baby soft upper layer.
They feel awesome and make up for an out of the box not so good ride on these vehicles. I'm lazy so had found a shop. Left in shop for 7 hrs and $750 later (austin) - best money I ever spend on this truck.
Re-upholstered Leather Seats + Seat Heaters-new-seats-foam-small-file-jpg
Old 06-24-2020, 08:31 AM #11
Real Name: Patrick
Real Name: Patrick
Thanks for taking the time to respond. Any advice or tips/tricks to make this any easier? What size hog rings will I need?
Old 06-24-2020, 09:37 AM #12
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Do you have the name of the shop? I would love to put Pleather in my 3rd gen. I know some people think it's tacky because it's "fake leather" but the newer stuff is great and holds up just as well or better than leather.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 12:07 PM #13
Ser1clymb's Avatar
Ser1clymb Ser1clymb is offline
Ser1clymb is on a distinguished road
Ser1clymb's Avatar
If you're just looking for the leather, I found a guy on eBay (Wolfman Auto and Cycle) that makes synthetic stuff specifically for our generation 4runner. I installed bottoms and uppers on both front seats and it is great. I think it matches the factory perfectly.
"Bettie" - 1998 4runner LTD E-Locker Evergreen Pearl 275K+, Alpine HU, Infinity Reference Speakers, Airraid MIT, B&M Cooler, Light Racing UCA, RCI skids, Bilstein Tundra 5100 and 4runner Eibach Coils in front/ Bilstein FJ 5100 and OME 890 rear, LC80 wheels wrapped with MT Baja ATZ 285/75/16, 99+ overhead console, 99+ center console, sound-deadening, Ditch lights
Ser1clymb is offline   Reply With QuoteReply With Quote
ebay , foam , mcgeorge , seat , upholstery
(5Gen Official Baby Car Seat Photo Thread)Baby car seat on brand new 18 leather seats Axix23 5th gen T4Rs 12 12-25-2020 02:36 PM
I installed seater heaters in cloth seats calimobber 3rd gen T4Rs 5 02-03-2019 02:18 PM
Clazzio Leather Seat Covers with Rostra Seat Heaters DarenS 4th Gen T4Rs 12 05-06-2014 12:02 AM
WTB: RSX seats or other Leather Bucket seat funnymeatball Want to Buy/Trade 0 05-05-2013 11:38 PM
2006 - Pre-wired for seat heaters? Power seats? tj043 4th Gen T4Rs 2 01-08-2012 03:48 PM
