Old 04-23-2017, 05:43 PM #1
johnnyd2723's Avatar
johnnyd2723 johnnyd2723 is offline
johnnyd2723 is on a distinguished road
Crank Pulley Damper Broke, Can I drive it 1 Mile?
Happy Sunday all! I have a question on driving my broke 97 Limited back up to my local garage less than a mile away. Here's the story:
A few weeks ago I purchased a 97 Limited with 111k on the clock. Not knowing whether or not the timing/water pump had been changed I decided I would go ahead and do it. Made the appointment and the work was completed Friday, picked it up Saturday. Today I drove to the grocery store and back home and then up to fill her up. When I started it back up it made this gawd awful noise like the fan was hitting the shroud or something but more metal sounding. I babied her home (again less than a mile) to find that the fan was fine but the damper part of the crank pulley had separated/broke. I literally pulled it out with one finger. So now, obviously this needs replaced and I have to take it back up there, is it going to be ok to drive? What could happen? Thanks in advance!
97 Limited
10 SR5
05 F150 Lariat
69 Chevelle
johnnyd2723 is offline   Reply With QuoteReply With Quote
Old 04-23-2017, 06:12 PM #2
baja1 baja1 is offline
baja1 is on a distinguished road
but the bolt and washer are still in place?
baja1 is offline   Reply With QuoteReply With Quote
Old 04-23-2017, 06:27 PM #3
Yes, I cant see them but it feels like it
97 Limited
10 SR5
05 F150 Lariat
69 Chevelle
Old 04-24-2017, 11:28 PM #4
TheFatGuy TheFatGuy is offline
Real Name: Bryan
TheFatGuy is on a distinguished road
Real Name: Bryan
It appears that the metal piece where you can hold down the crankshaft separated from the pulley, you are going to have source a new damper, i dont recommend getting a used one.
2000 Toyota 4Runner Base 2wd - Sold
1999 4Runner SR5 4x4 - Tundra Brake Upgrade- 2nd Gen Supercharger - 7th Injector - 32'' BFG KM2 Mud Terrains - ELocker - 4xinnvations Front Bumper
TheFatGuy is offline   Reply With QuoteReply With Quote
Old 04-25-2017, 08:46 AM #5
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
NO. If it got you home, then find another means of transportation. I won't go into how much worse it can get.
I'd search Car-Part.com--Used Auto Parts Market for a used one.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 04-25-2017, 09:43 AM #6
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Interesting.
When my 4R was still my brothers, this exact same damper broke off exactly like the OP. He tossed the ring in the back seat and its been about 15k miles later, still no damper on it. It is essentially a round weighted ring that is spot welded (i think) in place.
It is sitting on my bench in my garage as we speak.
Maybe I should replace it? At the same time, everything has been fine for about 15k miles. It did make removing the crank bolt a lot harder since there is less area for the bolts on the pulley holder tool to bite into. My guess is the torque of using the bolts in the pulley holder tool weakens the spot weld (or however the damper is held on) and it eventually comes off.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 04-25-2017, 09:54 AM #7
thegipper's Avatar
thegipper's Avatar
Here's a thought, why not just use a couple bolts to secure the metal ring in the picture back onto the pulley. The bolts would be the same size that you would use if you were using a pulley holder tool.
What is the purpose of that metal ring? Is it just for using aiding in use the pulley holder tool or does it have some other purpose?
Or is this in insanely stupid idea?
2011 Camry SE V6
Old 04-25-2017, 12:58 PM #8
thegipper's Avatar
thegipper's Avatar
I did a search on a bunch of previous vehicles I owned and looked at their harmonic balancer pulley's and none except the 4R have this metal ring on the inside. Since it is a solid piece of metal spot welded to the pulley, I'm willing to bet that it is just used for aiding the pulley holder tool bolts.
The solid metal ring wouldn't do any "dampening", that is what the rubber in between the pulley's does.
I'm not saying don't replace it, I probably should but the harmonic balancer is expensive! My ring fell off several years ago and thousands of miles later with no ill effects that I know of. It did however make it much harder to secure the tool to the pulley without having that metal ring on the pulley.
2011 Camry SE V6
Old 09-04-2019, 01:20 PM #9
It Still Runs It Still Runs is offline
It Still Runs is on a distinguished road
Hello All,
This is my first posting to the site and I was very excited to find this thread with the exact same issue I had yesterday with my 98 / 3.4 / 286K miles. Just like in the original posters message, I was moving my truck in the driveway when I suddenly heard a nasty sound like the fan was rubbing on something. I got under the hood and was looking at all of my pulleys and belts when I noticed the metal inner ring of the crankshaft pulley as seen in the original posters picture sitting half way out from the pulley haha. I attempted to pull it out with my finger and it dropped down onto the skid plate where I have yet to retrieve it from. After doing a bunch of reading and considering there is aftermarket light weight pulleys available, is it safe to assume that running the truck indefinitely without this heavy chuck of metal on the crankshaft pulley will have no I’ll effects on the engine? I don’t foresee any timing belt changes before the truck heads off to 4Runner heaven. Please help me out with any advice as I do not want to replace anything that I don’t need to as the frame is really starting to go.
It Still Runs is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 04:33 PM #10
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
Most people wouldn't notice if it fell off...run it and if you happen to notice any new noise or harshness replace it.
SaulG is offline   Reply With QuoteReply With Quote
Crank Pulley Holder alumarine 3rd gen T4Rs 4 11-08-2016 02:04 PM
WTB 1st Gen Crank PS/AC Pulley Naked Runner Want to Buy/Trade 2 01-26-2016 06:46 PM
Crank Pulley broke! KurtL 3rd gen T4Rs 19 08-10-2015 12:02 AM
URD crank pulley GX4SEVEND 3rd gen T4Rs 4 07-20-2013 07:34 PM
Crank pulley prodigy2k7 Classic T4Rs 9 01-09-2008 05:42 PM
