09-05-2019, 10:38 AM
#16
What's the reason many of you are changing out the A/C belt tensioner? Known problem spot?
2000 4Runner 4WD - lifted, e-locked, TRD supercharged 5-speed | MY BUILD THREAD
09-05-2019, 11:18 AM
#17
Most change it out because a new one comes with the Ebay kits.
They can go bad (its a hyd cylinder) and its easy to change when the belt is off.
wyndscreen.com
09-05-2019, 02:11 PM
#18
I was just shy of $300 when I did mine. That included the cheaper aircabinman kit from ebay, radiator hoses and coolant (neither of which was Toyota). Probably should have used Toyota hoses but what I went with works. Previous owner had used green coolant so I just went with it again. Didn't replace crankshaft pulley bolt.
1996 SR5
09-05-2019, 08:27 PM
#19
Originally Posted by snydmax
Don’t forget to grab a new crank pulley bolt!
Got one of those as well!
@ paddlenbike
- my A/C belt tensioner was broken, the bolt looked like it broke off a long time ago, no way to get it out of the bracket without cutting it to pieces. The bearing is sealed into the pulley so there's no feasible way to replace just the bearing. The part from Toyota came with the adjuster "stud", pulley and bearing. You have to buy the long adjuster bolt separately. Both parts were right around $40 together.
'99 Limited, 225K miles, 3.4/automatic, multi-mode, e-locker, broken sunroof, no DRL's. 265-75-16 Hankook Dynapro ATM. New Moog rear springs, KYB Monomax F&R.
09-05-2019, 08:53 PM
#20
Real Name: Teri
Real Name: Teri
Since I am not that handy or have help with stuff, I had it done for $800 or so back in March. Also oil change and coolant change. Part of the problem was that it's rusted and some bolts broke so they had a time getting those out.
Thing is, had to go back 2 days later cuz he didn't tightened the coolant line enough and then I had that power steering pump screech.
I took it to another mechanic and he fixed the screech no charge and just did my starter for a reasonable price.
hoping it all stays good for a few more years. I'd like to go on some long drives and enjoy the wild places.
99 Limited Silver/Tan 145K, Love this old thing.
16 Sonata Sport, Red with Grey interior.
09-05-2019, 09:37 PM
#21
Real Name: John
Real Name: John
Sounds like people are mistaking the TB belt tensioner for the A/C belt tensioner. BUT, my stupid A/C belt tensioner was starting to rust up because it's down the bottom. I'm sure some people end up replacing it. The bearing goes bad too.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
09-06-2019, 12:59 AM
#22
@ paddlenbike
I do have a new crank pulley bolt on the list, but thanks for the reminder. I'm also considering replacing the bracket that holds the fan as it has a bearing in it as well. I've seen others replace it when doing a timing belt job.
09-06-2019, 09:43 AM
#23
Yep.. I did mistake the verbiage. The TB tensioner comes with the kit.
My AC tensioner is looking questionable too. The adjusting bolt is a bit wobbly. Maybe I should replace it while in there.
Thanks
wyndscreen.com
09-06-2019, 03:59 PM
#24
I'm at $696.01, which included tax and shipping. Toyota quoted me 1800 just for the TB/WP/T-stat. These were all Original Toyota Parts:
Timing Belt
Crankshaft Pulley Bolt
Idler Roller
Tensioner Roller
Water-Pump (w/gasket)
Thermostat
Thermostat Gasket
AC Compressor Belt
Alternator Belt
Power Steering Belt
Radiator Hose Upper
Radiator Hose Lower
Toyota Red Coolant
Dipstick Tube O-ring
Radiator
Crankshaft Oil Seal
Transmission Fluid
These were all Preventative Maintenance replacements, including the Radiator (which was fine). The car had 185k miles AND on the original TB, FWIW.
I did not do the VC since I knew I was going to put in an SC eventually.
EDIT: Took about 2 hours in total, one of the most straightforward projects I had ever done. I guess it's small consolation for the "gotchas" I've had to deal with on EVERYTHING else car related!!
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
09-06-2019, 04:30 PM
#25
Real Name: Jerod
Real Name: Jerod
Thanks
Every 5VZ-FE I've ever worked on had that wobbly A/C tensioner bolt. It always bends under the tension. Yet to ever see one break though.
09-18-2019, 01:04 PM
#26
Tightened the wobbly AC tensioner bolt back up and all is good.
Except for the massive oil leak that I have now, but that's another story.
wyndscreen.com
09-18-2019, 05:27 PM
#27
Originally Posted by Sparky 97Runner
I got the Aisin kit from Rockauto for $175. It comes with water pump, gaskets, hydraulic tensioner, and Koyo tensioner and idler bearings. With shipping and coolant I'm in around $250.
I bought the exact same thing, and a new radiator. Did it myself.
09-18-2019, 11:40 PM
#28
I was pricing out this job as a diy project. Then I called a job who said they will use the Aisin kit and install the TB and WP for $850 out the door including parts and labor... I usually do my own tb and WP but it is tempting to let someone do it for a reasonable price like this..
Sent from my Mi MIX 2S using Tapatalk
09-19-2019, 06:46 AM
#29
I've been there before, and in all cases (with One exception, a mechanic who specialized in just my weird vehicle and was very enthusiastic), I was disappointed. Not that the work didn't get done, but it was sloppy. Missing fasteners, broken clips leaving dangling wires/hoses, sometimes scratches on the body from someone leaning on it, etc...
I started doing mechanic work because I couldn't afford to pay others, I continue because the older I get, the more the saying "If you want it done right, do it yourself" presents itself as true.
09-19-2019, 10:31 PM
#30
I had a local shop in rural NC do it for $230 with the kit I brought them. Bought the kit (T belt, tensioner, water pump etc) years ago to install myself but couldn't get the crankshaft bolt off. The kit sat on the shelf until I shredded the belt this summer.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
