Old 09-03-2019, 10:26 PM #1
2ndhandyotaman's Avatar
2ndhandyotaman 2ndhandyotaman is offline
2ndhandyotaman will become famous soon enough
How much did you spend on the T-belt job?
I just got done adding up all of the invoices from the Toyota parts dept, the eBay invoice from aircabinman, a few from Napa and a few from a local commercial parts store in the industrial park where I did the work at.
So for the t-belt kit, coolant, hoses, new A/C compressor belt tensioner, V/C gaskets and associated pieces, a fresh tube of FIPG and some new plug wires, I'm in it for about $830.
Add that to the cost of the trans fluid exchange and odd parts, I'm right around $1K in August for knocking out the last of the maintenance list on the old 'runner
'99 Limited, 225K miles, 3.4/automatic, multi-mode, e-locker, broken sunroof, no DRL's. 265-75-16 Hankook Dynapro ATM. New Moog rear springs, KYB Monomax F&R.
2ndhandyotaman is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 01:57 AM #2
4rFrog's Avatar
4rFrog 4rFrog is offline
Real Name: Totyota
4rFrog is on a distinguished road
4rFrog's Avatar
Real Name: Totyota
DO IT ALL, or you will be back in there redoing stuff.
2002 limited 4runner, Supercharged/7th injector/2.2 Pulley, Level 10 bulletproof transmission, 3" lift with 2.5 Fox Coilovers up front, Fox 2.0 reservoirs in the back, Toytec 3" springs in the back, Rokman lower links, Frontrange upper links, 285/75R16 Wildpeak ATW3's, SRQ Retrofits, Flowmaster 50 series SUV, New leather seats and steering wheel wrap, 4xinnovations bumper up front.
4rFrog is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 06:20 AM #3
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
That seems oddly high... For V.C gasket and new T belt job.
I was looking at 550ish max for all of that whenever I was pricing it out. Aircabinman is definitely the way to go, and check out partsouq.
I am not a fan of Toyota parts deal, slower than dead road kill in processing orders.
Throwing in the wires, and I'm guessing your doing spark plugs as well is where your "few Little items" start stacking up. What does that cost? 60ish bucks? And I'm guessing your doing new half moons which isn't required.
Obviously you can cut the half moons out of the price but if you need new plugs and wire sets then by all means
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 06:51 AM #4
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
I just bought all of this and it looks like I'm at about $450-ish. Granted, it's all mixed in with a full suspension/bushing overhaul and a new radiator too so it's a little hard to tell without going through Every itemized line.
Brian. is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 09:34 AM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I checked my invoice from McGeorge toyota (online parts) and it cost me about $270 in parts for all the valve cover stuff including new half moons, spark plugs/wires, and pcv/pcv grommet. You can PM me if you want all the part numbers.
Old 09-04-2019, 12:06 PM #6
SupaSupra's Avatar
SupaSupra SupaSupra is offline
Real Name: Dalton
SupaSupra is on a distinguished road
SupaSupra's Avatar
Real Name: Dalton
I think I paid around $500 for a T-Belt kit from Toyotoa, and a Denso radiator when I did mine a couple years ago.
2001 4Runner SR5 2WD on 35" BFG KM2
Bilstein 5100/Toytec Springs LC 9 wrap/LC shocks.
Its a wannabe 4WD.
SupaSupra is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 07:51 PM #7
The plugs are less than 1 year old, I didn't replace them. The old NGK wire set was showing white corrosion on the undersides, so I got a new set for about $47 and the new tubes for the coils were about $20. The price of the rad and oil cooler hoses plus the concentrate coolant definitely bumped up the overall cost, those were around$125 for all Toyota parts. I just cleaned and re-used the 1/2 moons, no reason not to. I had to get the cam plugs new, they were about $20
I had a bit of a hard time understanding how I ran up the costs so high when the aircabinman kit is pretty complete, but looking at the receipts I can how it happened. I have a cash wholesale account at the Toyota dealer parts counter, so their prices were good. I guess this stuff just adds up. There was no way I was going to cut any corners, I have no desire to go this deep into the engine again. Getting the old green coolant out was worth the effort and now I have plenty of left over red coolant. I probably should have gotten 1 gal of the concentrate and 1 gal of the pre-mix, I would have had much less left over.
Old 09-04-2019, 08:30 PM #8
onemanarmy onemanarmy is offline
onemanarmy is on a distinguished road
doing the job right now, by myself.
about $450.
T belt kit, had to buy a new lower sprocket gear, cam holder to get the cam bolts loose, new crank bolt, and seal puller for all three seals.
wyndscreen.com
onemanarmy is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 08:56 PM #9
STI_MECE's Avatar
STI_MECE's Avatar
I feel your pain....prices stack up real fast when doing the job right the first is really what your aiming for
And in all retrospect, that job will end up lasting 90-100k miles? Which let's say you drive 20k miles a year, you won't have to do it again for 5 years.
So let that sink in for a minute....lol that 800 bucks is nothing when you stretch it out over that time span. Now you gotta cross your heart hope to die the motor itself is in good working order then it's a slam dunk from there!
If it makes you feel better the PO of my truck was a blowhole. I had to go complete suspension overhaul and new tires on my rig....I still haven't had a chance to do this job. It's the last big step I have to take. I'm already 3500 deep into mine lol without the timing belt and valve cover job. He never did anything right and that is the money it took to get it back right.
Old 09-04-2019, 09:12 PM #10
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
I got the Aisin kit from Rockauto for $175. It comes with water pump, gaskets, hydraulic tensioner, and Koyo tensioner and idler bearings. With shipping and coolant I'm in around $250.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 09:29 PM #11
toyotaspeed90 toyotaspeed90 is offline
toyotaspeed90 is on a distinguished road
When we bought our 5sp it came with a gates belt, napa water pump, a hydraulic tensioner, and one of the idler pulleys.
Bought the other tensioner, belts, hoses, and cam seals - maybe a total of $150.
Also paid about $170 for 3 large cans of A/C and a manifold/gauge set plus pump to to recharge the system after the timing belt job.
If I had bought the parts I would go with an Aisin kit. On the LX470 I just did that's what I ordered and was under $200 plus another $110 for the Aisin fan bracket. I didnt replace the fan bracket on the T4R as I wasn't thinking of it being a wear item- on the plus side the job is 10x easier than a UZJ100. The UZJ100 job was around $400 in parts but I used Red Toyota, which they seem to seriously admire.
toyotaspeed90 is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 09:59 PM #12
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
You must have bought a lot of small parts not mentioned because I would probably charge about $1000 to do a T-belt and V/C gaskets at my shop. (parts, labor & tax)
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 10:35 PM #13
Not too many small parts. PVC valve and grommet, intake gaskets and some vacuum hose to replace hardened/rotted hose and the can of red wrinkle paint for the VC's is what comes to mind. don't feel like itemizing everything, but it wasn't too many 'add on' parts. The biggest surprises were the A/C compressor belt tensioner assembly (around $40) and the plug wire set. I used a Beck Arnley V/C gasket set to save a few bucks, I hope that doesn't come back to bite on my backside.
As I was typing this, I was going through the receipts again and realized that I had a quote for parts at $125 that I never purchased, so I can take $125 out of the overall costs. That puts me at around $705, which seems better!
I had maybe $30 worth of cleaners and a cheap plastic tub for a parts washer tank, but those are things that I'll use on different projects so I don't account for them. They're more like "shop supplies"
If your shop can do this job for $1K and use Toyota parts, I'd say that sounds like a good deal for someone who can't/doesn't want to do it themselves !
Old 09-05-2019, 09:05 AM #14
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
Don’t forget to grab a new crank pulley bolt!
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 09:28 AM #15
snydmax's Avatar
Real Name: Matt
snydmax's Avatar
Real Name: Matt
About $550 for all major parts (not including miscellaneous Oreily runs)
$242.27 - AirCabinMan kit 190580749105
$182.88 - New Denso Radiator (NAPA)
$40.00 - New up/low rad hoses, coolant flush, big a** funnel (NAPA)
$82.00 - new crank bolt and Toyota coolant from dealer
FREE - homemade crank pulley tool (this actually cost me several beers!)
My drive belts had just been replaced so didn’t need those... couldn’t justify putting the 160k mile radiator back in though it was probably fine.
$830 , add , parts , plug , t-belt
How to spend some $$$ ccvortex 4th Gen T4Rs 12 10-26-2016 03:33 PM
$500 to spend...what should I get?? Araj82 5th gen T4Rs 19 07-04-2014 03:18 PM
if you had $10k to spend.. Jc12 3rd gen T4Rs 9 03-31-2014 10:20 AM
$1,500 to spend... PGRunner 5th gen T4Rs 7 03-01-2013 09:38 AM
have to ask before I spend $ MTDewX8 3rd gen T4Rs 7 02-26-2011 05:26 PM
