Old 09-04-2019, 04:21 PM #1
TejasRunner01 TejasRunner01 is offline
TejasRunner01 will become famous soon enough TejasRunner01 will become famous soon enough
Rear drums leaking or just dirty?
Hey everyone,
I have been having intermittent rear brake lock ups when trying to move after being parked over night. One rear brake seems to "stick" and not let go. Usually the thing that fixes it is to reverse and then move forward again. My research as led me to believe the parking brake may be over tightened or the cable is binding; however, I adjusted them previously with the same problem still persisting ( and replaced one of the rear brake cylinders ).. still having the issue which gets much worse in the cold.
I took the drums off today.. they really aren't wet like you would expect due to an axle seal leak. Could the drums just be dirty or maybe just need turning? I do notice a slight stickyness on the pads.. this could be residue from when the brake cylinder I replaced had leaked. Also I have already replaced the diff breather in case you are wondering.
Your thoughts are welcome!
Thanks
Sent from my Mi MIX 2S using Tapatalk
TejasRunner01 is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 04:40 PM #2
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
"notice a slight stickyness on the pads.. this could be residue from when the brake cylinder I replaced had leaked "
Shoe goo looks like possible contamination..your last pic should be a few more degrees inward to see the axle seal..or pull ABS sens.
If you have it apart CLEAN it up and lightly scuff glaze off shoes, take it for a spin?
SaulG is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 04:43 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Looks dirty/grimy to me but not a rear axle seal leak in my opinion. I'd also check your bell cranks to see if they are sticking. Mine were causing me to overheat one of my drums requiring replacement. Just a thought.
Old 09-04-2019, 04:56 PM #4
Thanks for your replies already.. so I cleaned it with brake cleaner, I'll do a light scuff before I put everything back together. Here are both axle seal. Covered with a nice coat of dust and perhaps the smallest bit of oil but it wasn't really "wet" until I blasted brake cleaner..
A new development, I peaked into both side rear drum cylinder dust boots.. milky liquid came out of both the passenger and driver's side.. I'm guessing that means both are compromised since it should be sealed completely when you look under the boots..
Old 09-04-2019, 05:11 PM #5
Real Name: Patrick
Real Name: Patrick
That's more of a dust boot than a seal. The axle seal we're referring to is in the axle housing inboard of the ABS sensor.
Old 09-04-2019, 10:32 PM #6
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
I don’t see evidence of a leaking axle seal. My vote is rusted and seized bell cranks.
BrianK14 is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 10:48 PM #7
19963.4lsr5 19963.4lsr5 is online now
[QUOTE=TejasRunner01;3350147]
A new development, I peaked into both side rear drum cylinder dust boots.. milky liquid came out of both the passenger and driver's side.. I'm guessing that means both are compromised since it should be sealed completely when you look under the boots QUOTE]
Is not too out of the realm of possibilities that someone removed the brake shoes and gravity pushed a piston out of the wheel cylinder which would let brake fluid collect in between the dust seal and the dry side of the piston. I have a clamp I use to keep the pistons from pushing out of the wheel cylinder while I have the shoes removed.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 09-08-2019, 01:33 AM #8
Hey everyone, thank you all for your posts! I ended up buying two new wheel cylinders and upgraded from the 15/16" bore that came with my rig because of the factory 15" wheels to the 1" bore that was equiped with the 16" wheels. I also realized how dry the contact points were between the hub and the shoes. After a good cleaning, greasing and wheel cylinder replacement we are back on the road. I'll update you if I have any issues!
Old 09-08-2019, 09:25 AM #9
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
The fibrous nature of the brake dust indicates to me that the brake shoes were contaminated with brake fluid when the wheel cylinder was leaking. Definitely will cause a grabby/ sticky brake especially when damp out or the brakes are cold. Clean the shoes with brake cleaner spray and sand them a a little. Sometimes I will take a torch and burn the gear oil or brake fluid out of the shoes. (carefully, you don't want to cook them.) Clean the drums out really well also. Make sure your e-brake bell cranks are not seized up as well. If not and cleaning the shoes and drums doesn't fix the problem, replace the shoes.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 09-08-2019, 11:38 AM #10
PatrickStapler PatrickStapler is offline
PatrickStapler is on a distinguished road
Rear Axle Seal Leak
This is what that looks like...
Kind Regards,
Patrick
PatrickStapler is offline   Reply With QuoteReply With Quote
Old 09-08-2019, 11:57 PM #11
Very informative! Thank you. I'll definitely follow that line of attack if I continue to have problems. I did not realize what the fibrous brake dust meant, now I do! I used brake cleaner on the shoes but I did not sand them.. I only lightly sanded the drums. Again, I'll post back if I have issues.
Also thank you for the picture of what a axle seal leak looks like! I definitely don't think I am having that issue .
Old 09-09-2019, 06:47 AM #12
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
It will take you 10 minutes to find out if the axle seal is leaking. Pop out the ABS sensor and look into the cavity. If there is any oil in there, the seals are blown. To me the brake slave cylinders are not leaking at all. They look dry.
A possible solution to leaking axle seals - Toyota 4Runner Forum - Largest 4Runner Forum
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 03:55 PM #13
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Literally, 10 minutes. I just crawl under and take a peek. No need to remove wheels or drop the spare. I can't believe people worry about this problem but are reluctant to just take a look for themselves.
If the ABS sensor is stuck, a gentle rotation cw/ccw rotation with a pair of slip joint pliers while gently lifting with a flat screwdriver will get it out with no stress. No muscle is needed on this part. Then put a little silicone grease on it when you put it back and it will continue to be easy to remove.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 04:28 PM #14
I nearly popped off the abs sensor but I read a few posts of people messing it up when taking it off.. I rested on maybe I shouldn't so I didn't even try lol. I figure you would find the oil all over the drum if that was the case anyways
Old 09-09-2019, 04:57 PM #15
Kanoe's Avatar
Kanoe's Avatar
Well, yes and no.
In my case I noticed the oil leak into the ABS cavity early. There was oil in the cavity, but none had migrated out to the brake area. So I was able to do the bearings and seals and Dr Coffee flip but my brakes and drums were still perfect and did not need to be replaced. So in a way, not checking could cost you a whole lot more.
-2001 Echo D.D.
brake , drums , parking , rear , replaced
Rear drums - what needs to be done here? ShooterMcGavin 3rd gen T4Rs 25 06-24-2016 09:38 AM
What rear drums are you using? Sherwood4Runner 3rd gen T4Rs 5 08-12-2012 10:35 PM
rear drums 4runner52 3rd gen T4Rs 23 02-21-2009 07:31 PM
WTB rear drums for a 3rd Gen entities Classifieds - buy & sell (no commercial ads please) 1 01-16-2007 10:42 PM
Rear Drums entities 3rd gen T4Rs 1 01-11-2007 04:12 AM
