Old 10-24-2019, 02:22 PM #46
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by BoomerBob View Post
Thanks Tim. I was trying to understand if doing this was possible with the bearing still on the axle. I guess I didn't need to buy the bearing removal tool after all. It will probably come in handy at some point I guess.
After giving it more thought I think I'll replace the bearing since I'll have the tools. What's another $60 at this point.... The rig only has 148k miles so I think I'll be good if I only change the seals on the other side.
By the way; I see the original tool maker added a plate to make it easier to remove the ABS gear and bearing but also bumped the price up to $269.
The company I bought my original tool from was Durasolid. This looks to be another manufacturer with the same design. Maybe these companies are getting the tool from the same supplier and just putting their name on it. But, $260 is a huge ripoff compared to Duane's tool (Donald-the-bonald) that sells for only $170 and is much better built and is more functional. With Duane's tool, you don't need a bearing splitter and you don't need a press sleeve either. We actually suggested Duane make the driver tool with the built in sleeve because the tool originally was only meant to pull the parts off. He listened to our suggestion and made the driver tool because I told him I was reluctant to back a tool that doesn't also help you drive the parts back onto the axle. He was smart to work with us on the design because he's making lots more sales now that we have that video showcasing his tool. On top of it, Duane is a really cool guy so I'm glad we're helping him out instead of some company like Durasolid who never even once thanked us for plugging their product in our videos and generating tons of sales for them.
Old 10-24-2019, 02:44 PM #47
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
That's the one I bought; from Donald the Bonald. Besides being $100 cheaper; it's a better tool for the reasons you mentioned.
Rear Wheel Axle Bearing Puller & Tone Ring Tool /Installer Toyota 4Runner et al | eBay
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 04:53 PM #48
TejasRunner01 TejasRunner01 is offline
TejasRunner01 will become famous soon enough TejasRunner01 will become famous soon enough
Do any of you know a way to get the retainer off in order to put a new on "flipped" as @Drcoffee suggested without a press? I am a bit nervous to use a cutting wheel because if I am not going to the trouble to replace down to the bearing I don't want to score the skid control rotor or the axle shaft.
Thoughts on how to get the retainer off? I think you could possible heat it up enough to get it on 5mm passed polish.
TejasRunner01 is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 04:54 PM #49
Old 10-24-2019, 05:22 PM #50
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Even if you get the retainer off without a press you will still need a press to put it back on.
Old 10-24-2019, 05:47 PM #51
I have been looking into getting a press, looks like you can get a 12 ton HF press for $89 atm.. The hard part is investing another $170 into the SST tool. Sounds like $500+ is going to get spent changing the bearing minimum, or $175ish is getting spent repairing inner seal, o-ring, flipping retainer, repacking bearing and new shoes. This is assuming I can somehow flip the retainer without a press.
Old 10-24-2019, 06:50 PM #52
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Go ahead and splurge on the 20 ton press. It's not that much more and it can handle all the jobs on your 3rd Gen. If you ever need to do front wheel bearings, that 12 ton press might not cut it. If you like to wrench, the 20 ton press is a no-brainer.
As for the axle tool investment, if you don't want to keep it, put it back up for sale on Ebay for a slight discount over a new one and you'll get some of your money back. Maybe try to sell it first on Craigslist to save the shipping and fees from Ebay.
At the end of the day, you're still saving lots of money. Dealerships and other shops charge big money for this repair and then screw it up.
Old 10-24-2019, 07:09 PM #53
Thanks Tim, I surely appreciate all of your input. This is probably the route I will eventually take as I do enjoy wrenching.
What is y'all's thoughts on just putting on new shoes since nothing is in the drums as a bandaid until it eventually seeps through the bearing? The bearing is being lubricated currently, the bearing is tight and the abs sensor is magnetic so truly I don't know what it is hurting at the moment. Also.. could this be because I used synth gear oil??
Sent from my Mi MIX 2S using Tapatalk
Old 10-24-2019, 07:29 PM #54
BoomerBob's Avatar
BoomerBob's Avatar
Not really. By using a 1.5" pipe you can slam it home. Go to the 5 minute mark in this video to see how. You will notice they used a homemade tool to press out the bearing earlier in the video so some kind of tool is still needed.
YouTube
Old 10-24-2019, 09:29 PM #55
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
The new retainer can be installed by heating it with a propane torch and then quickly run it down the axle. I would suggest putting a stop where you want it to sit. Once it cools it will shrink to fit.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 11:39 PM #56
BoomerBob's Avatar
BoomerBob's Avatar
FYI: The HF 20 ton press is on sale again for $149.
20 Ton Shop Press - Hydraulic Shop Presses on Sale
Old 10-25-2019, 08:50 AM #57
Real Name: Patrick
Real Name: Patrick
I stand corrected. There are several shady methods available to install another retainer with the hopes of getting it in the right spot.
Old 10-25-2019, 09:20 AM #58
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
Your problem is the gear gear leaking into the rear drum. do not use brake cleaner because this product has acetone in it and it will destroy all the rubber seals. use mineral spirits to clean it up then check to see after a few days where the leak is ,, use a paint brush in a container with the mineral spirits .. also do the brake pads to remove the gear oil..
replacing the axle bearing on these is not a good day need special tools..possible the axle is worn and the seal cannot work..
catrains is offline   Reply With QuoteReply With Quote
Old 10-25-2019, 10:03 AM #59
Real Name: Patrick
Real Name: Patrick
The inner axle seal is leaking. That's literally the only way you are getting gear oil in the abs cavity short of putting gear oil in there through the abs sensor hole.
Old 10-27-2019, 11:44 AM #60
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
There is no real outer seal as such. There is the rubber dust boot seal, and the bearing side plate but there is no real oil seal on the outside of the ABS cavity. If you have that much oil in the cavity, you have external leakage or soon will.
Didn't this thread start with you having gunk build up and sticking shoes? Leaking gear oil.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
brake , drums , parking , rear , replaced
Rear drums - what needs to be done here? ShooterMcGavin 3rd gen T4Rs 25 06-24-2016 09:38 AM
What rear drums are you using? Sherwood4Runner 3rd gen T4Rs 5 08-12-2012 10:35 PM
rear drums 4runner52 3rd gen T4Rs 23 02-21-2009 07:31 PM
WTB rear drums for a 3rd Gen entities Classifieds - buy & sell (no commercial ads please) 1 01-16-2007 10:42 PM
Rear Drums entities 3rd gen T4Rs 1 01-11-2007 04:12 AM
