Old 09-05-2019, 12:59 PM #1
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
So, is this a sign of a failed axle seal?
Photos are of the ABS sensor space, one sensor (wiped the other off before thinking about it) ~ there's not really a lot of Obvious goo in the drums, but enough to get me investigating.
Drivers side:
Drivers side sensor:
Passenger side:
Pulled the breather, it moved freely when I pushed on it but when I introduced cleaner, it didn't pass. Pulled it apart (already had a replacement) and it looked like the rubber seal had glued itself to the opening.
I'm afraid I know the answer, just want confirmation.
Brian. is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 01:18 PM #2
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
Looks like you got wheel bearing grease on the sensor, so yes it looks like a failed axle seal.
APhelps is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 01:36 PM #3
TheLincolnGreen TheLincolnGreen is offline
TheLincolnGreen will become famous soon enough
Any fluid on the inside of the tire? That's how I noticed mine.
TheLincolnGreen is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 01:41 PM #4
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Do you have oil (not grease) running down your tire? A sure sign of a failed seal is diff fluid running down your tire or backing plate.
Usually when a seal fails it's due to your wheel bearing being shot. When a bearing has too much play in it, it'll cause the seal to fail, and fluid to come out of the housing.
Mike
MStudt is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 02:38 PM #5
Brian.'s Avatar
Brian.'s Avatar
Nope, insides of tires (I've only driven 2k since buying, just cleaned the insides of the wheels/tires today for the first time) have no sign of oil/dripping/leakage. 20 years of brake dust that was never cleaned from the rim in one uniform coat, but that's it. Fronts were the same (though I don't think the PO rotated tires, they have very distinct wear issues), no fluids and never cleaned with a very uniform coating of brake dust.
Alright.... no money in the budget, gotta think on this. This isn't something that's going to catastrophically fail in an instant (like a LBJ), right? Just a wheel bearing that gets noisy and oil that leaks on the tire and brakes (I'm not a heavy brake user), right?
Old 09-05-2019, 02:53 PM #6
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
You can tell the diff fluid has never been changed by the color of it. Nothing will if you don't change the bearing right away, but you will start to feel some vibrations in the seat as they go. As the bearing get worse you'll start to notice fluid seeping out.
Mike
Old 09-05-2019, 02:53 PM #7
Andy in Pa Andy in Pa is offline
Andy in Pa is on a distinguished road
Mike
X2.... Your fine... Yes, at some point a little gear oil has probably burped its way in there, and that could also be wheel bearing grease.
You have a bad seal when gear oil is soaking your brake pads, and leaking out the back of the brake drum backing plate, or is dripping down your tire.
Andy in Pa is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 04:05 PM #8
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
It doesn't look like too much fluid so you may be able to get away with replacing just the axle seal. I'd pull the axle shaft and inspect your wheel bearings. For what it's worth my brand new OEM wheel bearings had a little side to side play as in I could pull the outside of the bearing towards and away the splined portion of the axle shaft.
Bad Luck is online now   Reply With QuoteReply With Quote
drivers , pulled , seal , sensor , side
Rear Axle Seal: Axle Puller Tool Design nobb 3rd gen T4Rs 29 11-23-2019 07:39 AM
Is my axle seal in too far? Trojan4x4 3rd gen T4Rs 11 09-27-2017 05:06 PM
Inner seal/ axle seal replacement razzman1 4th Gen T4Rs 4 08-27-2015 07:07 PM
ugh...axle seal thebrandon 3rd gen T4Rs 0 06-23-2012 11:14 PM
Failed Inspection! Rear Axle Seals Leaking? HELP! David D 3rd gen T4Rs 3 06-08-2009 08:24 PM
