Old 09-07-2019, 09:25 PM #16
PatrickStapler PatrickStapler is offline
PatrickStapler is on a distinguished road
On the outer boots yes. Those look like mine. However, the inners are completely different. WTF do they need to be different? I will never understand automotive engineers.
Kind Regards,
Patrick
PatrickStapler is offline   Reply With QuoteReply With Quote
Old 09-07-2019, 09:38 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by 4RunnerBank View Post
I do. They don't require a specialized installation tool, they won't rust like an improperly selected steel band, they are impervious to oil/grease, they don't run the risk of cutting into the boot as an over-tightened band clamp might, and they are just as tight as the OEM band clamps. Pretty much every performance shock company uses them for their boots, albeit much smaller and less substantial than the ones I used for the CV boots.
We shall see.. :-) Keep us updated.
Old 09-09-2019, 11:11 AM #18
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
I think I'll just use zip ties after reading this. Although I've come to realize there is a big quality difference between cheap and expensive zip ties. I only use the fancy ones rated for extreme temperatures and UV resistance.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 11:23 AM #19
onemanarmy onemanarmy is offline
onemanarmy is on a distinguished road
Why use zip ties?
You got the correct clamps. Did you watch the reboot/CV joint replacement Timmy the Toolman vid? I believe he used the factory 'fold over themselves' Toyota clamps.
wyndscreen.com
onemanarmy is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 12:48 PM #20
Originally Posted by onemanarmy View Post
Why use zip ties?
I did exactly this...even he commented on the effectiveness of the OEM type clamps, but used them anyway. This is what prompted to ask here. If it's good, it's good and I'm OK with that.
Kind Regards,
Patrick
Old 09-09-2019, 03:30 PM #21
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Originally Posted by brillo_76 View Post
How long do you think your plastic zip ties are going to hold?
I don't know how long they're supposed to last but my cv axles have had the same harbor freight zip ties since 2015. I'm not recommending zip ties if you have the means to install the appropriate clamps but I wasn't able to get the new OEM clamps installed with the tools I had available at the time. I bought cv boot clamp pliers a few months later & been meaning to replace them with the OEM clamps I have for the last 4 years. I've used zip ties on another 3rd gen and those cv axles still have the same ones since 2016. They seem to hold up fine if the correct clamps are unable to be installed.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 10:26 PM #22
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Interesting. I honestly would never use even Duponts 66 nylons zip ties for cv joint clamp. :] I am glad they held for you the risk of that zip tie breaking or even leaking grease out would be extremely high in my opinion. Especially in the winter when ice builds up on the axles [ if you live in the rust snow belts] I seen ice and snow build up significantly on the cv joints and boots and even cause slight balance issues until it warms up some and melts off.
Old 09-11-2019, 08:12 AM #23
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Anyways, to answer the question of this thread title
SST 09521-24010 is the tool for the small clamp
Clearance check tool is SST 09240-00020
Clearance of .8mm [.0031 in] or less
From FSM SA -20 Front Drive Shaft CV Joint Boot Pliers-20190911_080158-jpg
Old 09-11-2019, 09:37 AM #24
Thanks Brillo
I have two sets of pliers for those type clamps. These are the type clamps I removed from my OEM joints and what I received with the new boots.
Kind Regards,
Patrick
Old 09-11-2019, 11:13 AM #25
Success!!!
After more searching, I believe I have found the correct pliers...
https://www.amazon.com/Qbace-Joint-B...gateway&sr=8-4
Kind Regards,
Patrick
Old 09-11-2019, 11:19 AM #26
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh dear. No way does that match the FSM..LOL You 100% sure those are OEM boots and OEM Bands?? or is someone selling you an OEM Boot with a different Band? Very common for Ebay and Amazon to do things like this.. :-( Sorry, I couldn't be more helpful.. I haven't ran into clamps like that yet. Glad you found a tool for them. :-)
Old 09-11-2019, 11:41 AM #27
OEM Boot Clamps
Fairly certain...everything else was. Timmy actually mentions them in his video as well.
Kind Regards,
Patrick
Old 09-11-2019, 08:39 PM #28
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Interesting.
I did send an email to my dealer parts department asking about those pliers for cv joint boots several days ago. So far all I got was crickets. It would be a different sst part number for sure then FSM mentions. Most have changed the setup of bands at some point. Most of my rigs all have original front axles still in them but the one as the boots got damaged and starting leaking grease. So I swapped the axles and seals when I had the half shafts out. :]
assume , back , boot , fold , pliers
Upper ball joint boot leak—replace UBJs or just boot kit? starclassic 3rd gen T4Rs 4 07-31-2016 02:50 AM
LCA ball joint boot jonb2 4th Gen T4Rs 29 11-22-2015 05:59 PM
Ball joint boot kit 4runnerAzGuy 4th Gen T4Rs 3 11-20-2013 04:23 PM
Replacing CV Joint Boot MCT4Runner 4th Gen T4Rs 3 02-06-2009 01:17 AM
CV Joint boot problem diverjeff200 4th Gen T4Rs 0 11-04-2003 09:52 PM
