09-06-2019, 10:37 PM
CV Joint Boot Pliers
Anyone have any ideas for the OEM style boot clamps? They are multi-layer that pull tight like zip ties then fold back on themselves. I would assume there are specific pliers to install these properly.
Yes...No?
Kind Regards,
Patrick
09-07-2019, 10:08 AM
Real Name: Patrick
Real Name: Patrick
Yes...No?
If it was me, I would use HVAC zipties and HVAC zip tie pliers. Sorry I can't be more help. I believe Timmy has a youtube video on rebooting front axles. He usually links to the tools he uses in the video description.
09-07-2019, 10:27 AM
I recently replaced my CV axles and try as I might, couldn't get the old clips off without damaging them. I used 11--inch zip ties that I found in the electrical dept at Home Depot. They worked very well.
Sent from my SM-G892U using Tapatalk
03 4Runner Ltd 4x4 V8, XREAS Delete, RAS Delete, Toytec 3" lift, GX470 Rear Spring Conv, JBA UCA's, Helo HE900 17x9, Cooper Disc 285/70/17
09-07-2019, 12:42 PM
I just clamped mine back up the other day and these are the bands I used with my pex crimped. Worked well so far.
1997 4Runner SR5 3.4 5spd, 213k, Sonoran 1.2,Crawler 1” body lift, Nitto Ridge Grapplers 255/80/17 on TRD Pro 17” Wheels, Custom Roof Rack.
09-07-2019, 03:02 PM
Real Name: Jon
Real Name: Jon
How long do you think your plastic zip ties are going to hold?
09-07-2019, 03:29 PM
I have Lisle (I think?) clamp pliers that do it but they didn't work as amazing as I hoped from what I remember but did the job. They look like this:
99 SR5 v6 4WD
11 SR5 v6 4WD
09-07-2019, 03:51 PM
They will outlast the rubber boot.
09-07-2019, 05:36 PM
If I had those type clamps, I’d be golden. I have two sets of those pliers. However, the OEM clamps are different.
I ended up using my T&G pliers, pulling as tight as I could, and folding it over itself. It actually ended up tighter than I expected.
Kind Regards,
Patrick
09-07-2019, 06:29 PM
Real Name: Jon
Real Name: Jon
You truly think so? Let us know how long they stay on there without leaking grease out or completely flying off causing all grease loss in the joint.
I can understand in an emergency out on a trail or something extremely temporary. So I am curious how long the tie stays put. :-)
09-07-2019, 07:14 PM
You truly think so?
I do. They don't require a specialized installation tool, they won't rust like an improperly selected steel band, they are impervious to oil/grease, they don't run the risk of cutting into the boot as an over-tightened band clamp might, and they are just as tight as the OEM band clamps. Pretty much every performance shock company uses them for their boots, albeit much smaller and less substantial than the ones I used for the CV boots.
09-07-2019, 08:04 PM
PatrickStapler. Making excellent progress in getting your rig back together.. :-) Your CV joints in decent shape without much play at 300k? My 02 Camry already had some play at 160k..
They are flawless. No play. Smooth as silk rotation...all six bearing assemblies cleaned up really nice. Only one outer roller showed any sign of visible wear. Repacked with the grease that came with the boots.
Kind Regards,
Patrick
09-07-2019, 09:20 PM
I think these are the OEM clamps. They are the ones on the original Toyo boots on my old CVs. The steering boots are similar. The ones on the Napa CVs I have on my 4runner have the "folded" ones though, which I have no idea how they crimp.
99 SR5 v6 4WD
11 SR5 v6 4WD
