Originally Posted by DK327
So I need to get my starter out to replace the contacts and the transmission dip stick tube is in the way. I know the top tube comes out (already removed the bolt) but it seems to be stuck to the bottom tube and I don't want to twist/pull too hard because I'm afraid the bottom tube that connects to the trans pan might break. Is there a trick to separate the top tube from the bottom tube that I don't know about?
Thanks in advance!
I had the same problem and I was about to try the vise grips, but first I used my pry bar. I got my pry bar - the one thats about 16” long with the slightly curved end- into a position where I had leverage to pull down on the pry bar handle causing the tip to rise and lift the top tube up and out of the bottom tube about a 1/4” until it popped free of the O ring friction.
Theres a “ridge” on the upper tube close to where it joins the lower tube, so put the tip of your pry bar right under that “ridge” and rock the pry bar like a see-saw until she lifts the top tube enough for you to just pull it right up and out.
Worked great after 30 minutes of frustration trying to twist and pull on the tube!! I guess these O-rings get gummy after many years contact with ATF.
Another headache was disconnecting the plug connection to the starter. I didn’t see any tab to push on so basically it was just blind groping and squeezing, but it worked.
