Old 09-07-2019, 11:00 PM #1
Sarki Sarki is offline
Sarki is on a distinguished road
MY GARAGE
MY GARAGE
How many cam plugs
Placing a parts order so I can tackle valve cover gasket replacement and wanted to confirm the amount of cam seals needed.
I know there are 4 half moons that can be cleaned up and reused but the cam seals should be replaced.
Assuming there are 4 (one in front & one at rear of each head) but parts diagram appears to indicate only one at the rear of each head and no reference to one at the front.
Can someone who has done the job please confirm.......thanks!
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 09-07-2019, 11:27 PM #2
PatrickStapler PatrickStapler is offline
PatrickStapler is on a distinguished road
I did mine last year. I couldnít see how to do the fronts without removing the entire front section of the engine. Caveat, Iíve only had mine a few years so the more experienced owners may know more than I.
Kind Regards,
Patrick
PatrickStapler is offline   Reply With QuoteReply With Quote
Old 09-08-2019, 07:04 AM #3
Brian.'s Avatar
Brian. Brian. is offline
Brian. will become famous soon enough Brian. will become famous soon enough
Brian.'s Avatar
2 cam seals at the front (usually done with a timing-belt change as the cam gears have to be removed). The rear are just 2 caps:
camshaft plugs (2) 11188-62010
that are only done with the valve cover gasket. Here's my parts list for just the Valve Cover side (and quantity/rough pricing). The cam and crank seals came with my timing belt kit via ebay.
throttle body gasket 1 22271-62040 $4.60
Plenum Gasket (2) 2 17176-62040 $9.91
valve cover gasket (2) 2 11213-62020 $24.80
PCV Valve 1 12204-62010 $9.76
PCV grommet 1 90480-18001 $4.40
half-moon plug (4) 4 11183-62010 $6.84
valve cover washers(16) 16 90210-05007 $1.01
camshaft plugs (2) 2 11188-62010 $9.61
sparkplug tubeseals (6) 6 11193-70010 $2.75
FIPG 1 00295-00103 $12.55
Good idea to do sparkplugs too, and wires if you don't know their age. I'm tossing in reman fuel injectors too, just because I really only want to take that whole mess apart once in the next decade.
Brian. is offline   Reply With QuoteReply With Quote
Old 09-08-2019, 09:16 AM #4
MY GARAGE
MY GARAGE
Thanks for response guys.
2 cam plugs/seals it is.
Iíll do the fronts when the timing belt/water pump service comes up over the next couple of years as one project at a time.
Trying to focus on getting ready for the salty roads headed my way in another couple of months.
2002 SR5 Sport 4WD
cam , confirm , front , head , rear
Twin ground electrode plugs vs. standard plugs 216133 Maintenance/Detailing 9 09-06-2019 10:37 PM
What do you gap your plugs at? I changed my oil, plugs and air filter and lost mpg judogti 4th Gen T4Rs 22 02-07-2013 10:48 AM
Old plugs far out of gap ... dta1984 4th Gen T4Rs 2 11-12-2012 12:51 PM
Why not use 100k mile plugs to replace the 30k mile plugs in the V6? Threxx~ 4th Gen T4Rs 24 12-05-2010 01:58 PM
pultar pulse plugs (not spark plugs) 3rdgengrog 3rd gen T4Rs 2 11-15-2008 04:44 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
