Old 09-08-2019, 12:29 PM #1
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
OBDII mph
auto equipped with abs
Anyone know if the vehicle speed/MPH that shows in live data comes from vehicle speed sensor #2 (sp2+, sp2-) at the ecu or does the ecu use the signal from the wheel speed sensors or something else....
clearock is offline   Reply With QuoteReply With Quote
Old 09-08-2019, 06:04 PM #2
It uses the speed from the ABS computer. I forget which input it is. I went through figuring out which speed input is used when I installed a factory NAV unit and needed the speed input to make the NAV accurate.
Old 09-09-2019, 01:07 PM #3
More specifically, is uses the signal from the ABS computer that is processed by the gauge cluster and sent to the ECU from there. With more context, we can help you with whatever you are getting at...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-09-2019, 10:48 PM #4
Thanks, I have all the wiring info (alldata, ondemand) but there is nothing that said specifically that the ecu outputs the mph by blank or blank... so i was looking 4 clarification to help diagnose an issue i was having. I lost my mph under obdII but along with random loss of my gauge cluster. Had a hard code for my RF ASB sensor and no cruise but all the individual parts, wiring, and sensors tested good. Ended up being the elocker sp1 wire grounding...
abs , ecu , signal , speed , vehicle
OBDII Scanner with ABS B1gfun 5th gen T4Rs 1 06-05-2017 10:27 AM
Hi to all, and Which OBDII brand to buy Bimmerman 4th Gen T4Rs 11 01-01-2008 01:34 AM
CAR MD OBDII Diagnostics JP4RNR 4th Gen T4Rs 1 12-26-2007 06:16 PM
OBDII PC Interface greasefingers 4th Gen T4Rs 2 07-13-2005 10:55 PM
OBDII & Accessories Satman Engines / Suspension / Wheels / Tires / Audio / Accessories 0 12-25-2003 03:02 PM
