Originally Posted by NEKExplorer
So the CEL has been on for awhile and getting the codes:
P0125 O2 Sensor heater Circuit
P0135 closed loop fuel control insuff temp
PO 171 too lean bank 1
PO 177 Fuel comp sens circuit
Would all this cause the vibration that seems to be coming from the right front though? Gas mileage is very good right now, wouldn't it get worse with all those probs?
When I redid the brakes recently I did notice the CV boot was ripped on the vibrating side and there seems to be a groove worn into the shaft (I do have a lift, SS 1.2) The CV dies not click or pop when turning though.
Thanks again
Yikes, that's enough to make the engine stop running altogether...
Start with the P0135 O2 Sensor Heater circuit. That's the front O2 sensor and costs only about $50 on Amazon. Honestly, that might clear all of them up. Install the sensor (simple, 2 bolts and one wire connector) and then pull either the EFI fuse or the negative battery terminal for about a minute and put it back in. See if the codes come back, if any.
Can I ask though who pulled the codes or what code reader you used? A P0177 isn't a possible code on a 3.4L 5VZ-FE, we don't have a fuel composition sensor.
