Old 09-09-2019, 05:22 AM #1
NEKExplorer's Avatar
NEKExplorer NEKExplorer is offline
NEKExplorer is on a distinguished road
Diagnostic help please
I have a 98 Limited 5VZ-FE 235k miles. Recently the truck has started vibrating/shaking when I give it gas/accelerate. It seems to run fine while idling but trying to accelerate/increase speed/climb hills causes shaking and it feels like either there is a loss of power or as if something is trying to hold the truck back.
This is a fairly sudden problem. I did wear out the front brakes very severely (literally wore the rotors down to the point the rotor face separated from the hub) so I wondered if maybe I messed up the rear brakes to the point something is locked up, but the wheels all turn fine. Also, I haven't one any off-roading or hard driving in the past 20k miles or so, just daily driving on pavement.
Thanks for suggestions.
"If the American people ever allow private banks to control the issue of their currency, first by inflation, then by deflation, the banks and corporations that will grow up around them will deprive the people of all property until their children wake up homeless on the continent their Fathers conquered...I believe that banking institutions are more dangerous to our liberties than standing armies... The issuing power should be taken from the banks and restored to the people, to whom it properly belongs."
NEKExplorer is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 05:55 AM #2
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
Or your front calipers are seized up.
What does your brake feel like?
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 05:57 AM #3
I just redid the fronts- new calipers and rotors, front brakes feel normal, just fine.
Old 09-09-2019, 10:05 AM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by NEKExplorer View Post
...started vibrating/shaking when I give it gas/accelerate. It seems to run fine while idling but trying to accelerate/increase speed/climb hills causes shaking... there is a loss of power
When this occurs does the CEL light flash/blink? Any CEL codes set or pending? Flashing CEL is indicating to back off the throttle, too much unburnt fuel is making it to the cat. Let us know....
Old 09-09-2019, 10:27 AM #5
So the CEL has been on for awhile and getting the codes:
P0125 O2 Sensor heater Circuit
P0135 closed loop fuel control insuff temp
PO 171 too lean bank 1
PO 177 Fuel comp sens circuit
Would all this cause the vibration that seems to be coming from the right front though? Gas mileage is very good right now, wouldn't it get worse with all those probs?
When I redid the brakes recently I did notice the CV boot was ripped on the vibrating side and there seems to be a groove worn into the shaft (I do have a lift, SS 1.2) The CV dies not click or pop when turning though.
Thanks again
Old 09-09-2019, 12:39 PM #6
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Does it feel like an engine misfire? Or a driveline vibration? I'm wondering if perhaps you have a failing driveshaft U-joint? Does the vibration occur when cruising at a steady speed, like on the freeway, or only when accelerating?
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 12:53 PM #7
The engine seems to run pretty normal, no skipping. The RPMs seem a little low, but only by maybe 500- sorta feels like if it was a standard transmission and you were trying to climb a hill in too high of a gear. Even when you make it downshift though it still vibrates and feels like something is pulling it down. Mostly its wicked vibration that seems to be coming from the right front and that feeling like something is holding the rig back.
Old 09-09-2019, 01:49 PM #8
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Thanks again
I’d definitely look into fixing your CEL’s first.. I’d also go under your truck and do a quick visual on your driveshaft/u joints. But if it drives normalish when your going downhill/flat then it would seem like it’s the engine/transmission.. Just from reading the CEL description your probably not getting enough fuel to the cylinders and that’s why your getting such good mpg.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 04:12 PM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Is the shaking/vibrating only while accelerating? If you get up to speed and then shift to neutral and coast does the vibration go away?
Old 09-09-2019, 07:32 PM #10
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Thanks again
Yikes, that's enough to make the engine stop running altogether...
Start with the P0135 O2 Sensor Heater circuit. That's the front O2 sensor and costs only about $50 on Amazon. Honestly, that might clear all of them up. Install the sensor (simple, 2 bolts and one wire connector) and then pull either the EFI fuse or the negative battery terminal for about a minute and put it back in. See if the codes come back, if any.
Can I ask though who pulled the codes or what code reader you used? A P0177 isn't a possible code on a 3.4L 5VZ-FE, we don't have a fuel composition sensor.
326WHP 347TQ
brakes , driving , fine , miles , point
Diagnostic help please? d_benet 3rd gen T4Rs 3 12-04-2016 02:57 PM
Need help with a diagnostic Dementedfish 3rd gen T4Rs 10 01-29-2015 07:50 PM
help with diagnostic 4x4yota Classic T4Rs 26 12-08-2013 01:24 AM
Need a little diagnostic help: GMo 5th gen T4Rs 7 09-30-2012 05:49 PM
Car MD (diagnostic) owen4runner 4th Gen T4Rs 1 08-31-2006 10:03 AM
